sealing tranny casing
Old Aug 22, 2006 | 07:06 AM
2mansi's Avatar
Default sealing tranny casing
Ok guys seems as if though when I sealed the transmission casing with honda bond that a little bit of it melted off....it leaks like one drop a day I'm one of those over worked freaks.....
Question is is there some sort of silicone or material that will allow me to seal the tranny from the outside.....I really don't want to take the transmission off again....
Old Aug 22, 2006 | 10:23 PM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
Default Re: sealing tranny casing (2mansi)
yes. make sure to completely dry the area, then seal liberally. don't drive till it has set for a couple hours. if it drips with the engine off, then drain, dry, then seal, then refill.
petty$rep
18
Oct 12, 2006 07:53 AM
Type_R_Lover
Apr 11, 2006 11:09 AM
turbotime
Aug 17, 2004 08:44 AM
