FS/FT: 1994 Honda Del Sol Si Rolling shell- NOVA
Means of Contact:pm/post or call 5713384794
Description:Finally got the car today, please note I'm taking a lot of parts off of this, so read carefully.
94 del sol si 241k+ miles on it, will come as a rolling shell, needs the following: Seats, exhaust, motor, tranny, ecu, engine harness. Asking for $750
It currently has the full ac setup still in the car, needs to add the belt and refill freon. Also power steering is working, along with cruise control and power windows. No radio, no speakers. Stock suspension, stock radiator. If you want parts necessary for a dohc vtec swap add $250. (axles, mounts, shift linkage.) I'm taking the seats because mines are broken, so no seats. I thought the body was in worse condition than actually seen, a little body work on the door and tighten up the bumper and it will look pretty good. Will come with 13 in rims w/ ok tires, brakes are slotted up front, stops great.
I am up for trades, turbo kit, wheels + cash, or any aftermarket B series parts. lmk what you have. I'm holding on to the tranny for a bit, so sorry, tranny is no longer available for sale.
Miles:241k+
Price:$1000 (ready for a dohc b series swap
Additional Information: motor available here
Pictures:
Modified by dorifto_83 at 2:36 AM 8/22/2006
Miles:241k+
Pictures:
can also sell as a running car, considering I really don't have time to pull the tranny. It would have a b16 w/ ctr cams, itr intake manifold, gsr t/b/ itr fuel rail, Jasma header, ITR JDM Lsd tranny. Just needsa clutch, asking for $3000 obo as is.
Where's the motor leaking oil from, you can see it next to the exhaust mani, also how many miles on the motor? Where did it come from?
EDIT:
Also do you want any trades?
I have a complete gsr motor for sale. Includes everything.
EDIT:
$2600
running car (clutch is gone, so it needs to be changed.)
Good
JDM B16A, gsr valve cover, ctr cams, itr intake manifold, gsr t/b, type R lsd tranny. Motor runs smooth, comes with a p28 ecu, no cel codes. Lowered on tokico 5 ways, slotted brakes.
Bad:
Some body damage, right window is off track, no radio or speakers. Passenger side seat doesn't have rails. Needs exhaust, tires don't grip even though they have decent tread.
I will trade for del sol aftermarket parts, or turbo kits (complete non ebay kits only.) Car is located in fairfax, va.
btw, the swap is still in the car, hasn't been removed yet. Don't have the time to do it right now ,thanks.
Good
Bad:
amy
Northeast (Sales)
61
Dec 7, 2005 03:19 PM
