SRS light is ON, any suggestions, using ctr srs & cluster
Old Apr 26, 2002 | 07:32 AM
B( * Y * )BIES's Avatar
Default SRS light is ON, any suggestions, using ctr srs & cluster
OK, About 2 weeks ago I installed my ctr srs steering wheel on my 99 dx hb.
No issues until the other day... I had noticed (2 weeks ago) that the s.w. looked a bit off center so I figured beginners error that it was off by a tooth and I should just pull it off and move it over a tooth.
Well it wasn't the tooth, it's the wheels out of wack... anyways when I re-installed the s.w. the srs light is now on.
I have been using my jdm ctr cluster for a while now and was also in when I installed the s.w. the 1st time.
~I have NOT YET checked to see if the srs connection is not on good, but I think the airbag would've exploded by now if that were the case.
Any suggestions / solutions?
Thanks
Old Apr 26, 2002 | 07:43 AM
Default Re: SRS light is ON, any suggestions, using ctr srs & cluster (B( * Y * )BIES)
WORD!
I found the old link with my answer.
Darn search feature sometimes doesn't work while I'm at work.
So nevermind!
Old Apr 26, 2002 | 11:33 AM
Trey's Avatar
25 Year Member
You took it off without disconnecting the battery.
sounds like you found the thread with the Helms fix.
If not get a Helms.....
Old Apr 27, 2002 | 06:41 PM
owen_the_soyboy's Avatar
Default Re: SRS light is ON, any suggestions, using ctr srs & cluster (Trey)
what was the fix?
my buds EK has the srs light still on same scenario too..
thanks.
Old Apr 27, 2002 | 07:25 PM
DR. ON POINT's Avatar
Banned
Default Re: SRS light is ON, any suggestions, using ctr srs & cluster (owen_the_soyboy)
**** the SRS light, I got a card over mine
Old Apr 29, 2002 | 09:56 AM
I did a search (on a diff pc at work) and found the link to the Do-It-Yourself and printed that out so i could fix it when i got home!
oh and I did have the battery disconnected
thanks
dumafit
Northern California (Sales)
Jun 7, 2011 04:13 PM
Cuda
Aug 25, 2008 05:25 AM
sea plant
Jun 8, 2008 02:04 AM
sk8shorty012
29
Jun 22, 2007 02:01 PM
fastfour
Jul 17, 2006 12:11 PM
