Cam Gear install
Old Apr 26, 2002 | 07:00 AM
Fooser's Avatar
Default Cam Gear install
Ok so I picked up some AEM Cam Gears that I plan on installing this weekend. What I want to know is what to do to install them. Do I have to remove the timing belt all together, or can I adjust the tensioner enough to slide the belt off the gears and install them that way.
I personally think it would be much easier if I dont have to take the pulleys off.
Old Apr 26, 2002 | 08:08 AM
94civicx's Avatar
New User
Default Re: Cam Gear install (Fooser)
you can just loosen the tensioner and slide the belt off.
Old Apr 26, 2002 | 08:14 AM
Fooser's Avatar
Default Re: Cam Gear install (94civicx)
Ya thats what I thought. screw paying some guys to do it. They wanted like $100 to do that. I think they quoted me at like $295 for Skunk2 cam gears and the work. This did include cutting the valve cover. I dont know tho maybe its worth it cause they have to cut the cover. I would prefer the moon cut instead of the straight cut across.
Right now I can probably pick up some AEM cam gears for around $150 or so give or take $10. So it all depends on how much money I have left over this weekend for the tuneing which is like $100.
If I can get the shop to cut my valve cover for less then $50 I will be set.
I like the way this looks the best.
[Modified by Fooser, 5:16 PM 4/26/2002]
Old Apr 26, 2002 | 11:58 AM
B00ST2nR's Avatar
Hey. That is sellin on eBay right now. Same Exact picture too.
Old Apr 26, 2002 | 12:21 PM
Fooser's Avatar
Default Re: Cam Gear install (b18c1 dc2 R)
Ya I know. I was bidding on one then the auction closed for some unknown reason with no winners. I'm not going to be bidding for that person anymore because of this. Looks to me like hes selling stuff he dosent have which makes me worry. e-bay is notorious for people like that.
Old Apr 26, 2002 | 12:54 PM
Dirt's Avatar
Also, try this link..... http://www.pmpdesigns.com/On-line_St...lve_cover.html
Old Apr 26, 2002 | 01:46 PM
Fooser's Avatar
Default Re: Cam Gear install (MmmVTEC)
Yup thats what I'm looking for. I think I will just have the shop cut my original valve cover tho. I'm going to bring in a picture and see what they can do.
Old Apr 26, 2002 | 02:32 PM
integra-modder's Avatar
anyone think its worth buying one of the newer valve covers and then maybe selling mine? (I got an 01 GSR with 11 K it but I want the red) Itll cost 215 for a new one, or its 55 if I get a red cover and send it to them.
Old Apr 26, 2002 | 02:35 PM
Fooser's Avatar
Default Re: Cam Gear install (integra-modder)
They sell those on E-bay and usually go for around $175-$195 with the plastic guard. I'm just on a budget and I dont want to really wait another two weeks for tuning. So I'm debating on what I need first.
This auction is currently at $135 if you want to bid.
http://cgi.ebay.com/ebaymotors/ws/eB...tem=1823583198
[Modified by Fooser, 11:38 PM 4/26/2002]
Old Apr 26, 2002 | 04:02 PM
C-speed's Avatar
Here's soem instructions.. its for installing cams.... but same process. Just don't remove the cams
http://www.c-speedracing.com/howto/caminstall/cam.html
Old Apr 28, 2002 | 08:55 AM
Default Re: Cam Gear install (G3-TEG)
hmmm...how hard is this? I can get access to phenumatic tools....
All I need is some guidance while im there.....
Also, what is Honda Bond? and where exactly do I put it?
Old Apr 28, 2002 | 12:40 PM
anyone? honda bond?
Old Apr 28, 2002 | 10:51 PM
Fooser's Avatar
Honda Bond is ghasket sealant. You will need to clean your ghasket and apply some on the corners where ghasket curves for the cams.
Old Apr 29, 2002 | 04:40 PM
SIK IN DA HED's Avatar
New User
it wasnt too hard. make sure you do it right. my friend didnt tighten the belts that tight and now my waterpump bearing is shot and who knows what else messed up over time. im currently getting all that **** repaired.
Old Apr 30, 2002 | 06:54 AM
Fooser's Avatar
Default Re: Cam Gear install (dlplayboy)
I'm suprised it didnt skip a few teeth by now if it was that loose. might want to check your timing.
carbonek9
Mar 2, 2006 11:13 PM
raysjdmh22a
Sep 4, 2005 07:07 AM
216.226.142.95:27016
Jun 27, 2003 11:46 AM
LethalX
Sep 9, 2002 12:21 PM
oryanh
Jul 6, 2002 01:52 PM
