how to uninstall valves,retainers??
first you need a vavle spring compressor. Maybe a pocket screwdriver with a magnet on the end of it. Compress the springs and remove the retainers and slide the valves out. Pretty easy. Use the magnetic end and pull the keys out when the spring is compressed.
I think you can rent the spring compressor from parts stores?
Why are you disassemling your head for?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fezzie »</TD></TR><TR><TD CLASS="quote">ok i have the spring compressor </TD></TR></TABLE>
OK now all you have to do is like crx1.8 said
Compress the spring using the tool
Use a magnet (usually a small pocket screwdriver with the magnet opposite end works best) to get out the two small valve keepers from the valve.
Once those are out you can uncompress the spring
Then the spring will come off and the valve will drop out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SVOboy »</TD></TR><TR><TD CLASS="quote">I usually take a 17mm socket, place it on top of the spring, and smack it with a hammer. Apart it comes.</TD></TR></TABLE>
Same.
Same.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesrv »</TD></TR><TR><TD CLASS="quote">
Same.</TD></TR></TABLE>
when you guys do this do your keepers come flying out? haha. ive never heard of this.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx1.8 »</TD></TR><TR><TD CLASS="quote">
when you guys do this do your keepers come flying out? haha. ive never heard of this. </TD></TR></TABLE>
They fly up into the socket then fall down into the head. Using a magnet you get them out. Easy peasy.
hell yea that work
