Suspension & Brakes Theory, alignment, spring rates....
Clicking on the right side
Old Aug 21, 2006 | 09:51 AM
chunty kevin's Avatar
Default Clicking on the right side
I have a gsr in my ek, its on blown tokicos and ground controls all the way on the bottom (no rubbing issues). there is a clicking sound coming from the passengers side. we thought it was the axels and i got that replaced. what do you guys think it is?
Old Aug 21, 2006 | 09:59 AM
rip94delsol's Avatar
Default Re: Clicking on the right side (chunty *** kevin)
does it click while moving or does it click while still if it clicks while not moving it could be your bushings on either arm!
Old Aug 21, 2006 | 10:01 AM
Default Re: Clicking on the right side (rip94delsol)
it clicks while moving. the sound is def. coming from the passengers side tho. tranny problem?
Old Aug 22, 2006 | 06:53 AM
lifted both sides up and rolled on first gear and i didnt hear anything. tires rubbing? its getting an alignment today.
Old Aug 22, 2006 | 10:19 AM
B16B_coupe's Avatar
HRD PKR
Default Re: (chunty *** kevin)
tires are prob hiting fenders.. my does a little
Old Aug 22, 2006 | 04:07 PM
chuniepatuni's Avatar
Default Re: (ek9bmxer)
could be the bearings and the hub
Old Aug 23, 2006 | 06:32 AM
Default Re: (chuniepatuni)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chuniepatuni &raquo;</TD></TR><TR><TD CLASS="quote">could be the bearings and the hub</TD></TR></TABLE>
how much would it cost to fix this?
Old Aug 24, 2006 | 12:08 AM
im not to sure.. but prolly around 700 if you get a shop to do it...
Old Aug 24, 2006 | 01:50 AM
bad-monkey's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chunty *** kevin &raquo;</TD></TR><TR><TD CLASS="quote">how much would it cost to fix this?</TD></TR></TABLE>
buy a wheel bearing from somewhere, pull your knuckle, take the bearing and knuckle to a place with a press, have it pressed in. it should cost you 70 bucks for the bearing, 20 bucks to get it pressed.
Old Aug 24, 2006 | 04:59 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (bad-monkey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chuniepatuni &raquo;</TD></TR><TR><TD CLASS="quote">im not to sure.. but prolly around 700 if you get a shop to do it...</TD></TR></TABLE>
If you pay 700$ you are a moron.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bad-monkey &raquo;</TD></TR><TR><TD CLASS="quote">
buy a wheel bearing from somewhere, pull your knuckle, take the bearing and knuckle to a place with a press, have it pressed in. it should cost you 70 bucks for the bearing, 20 bucks to get it pressed.</TD></TR></TABLE>
Wheel bearings are about 60$ each. (Do both at the same time). Take your knuckle off as bare as possible, and bring it to a shop. They will have them back to you in an hour or so for less than 100$.
Old Aug 24, 2006 | 05:29 AM
im sorry.. i overpriced him... i wasnt sure.. as i have never gotten one replaced...
Old Aug 25, 2006 | 03:08 PM
i can get the oem honda bearings for 80 all day and while your at it if you want to put extended wheel lugs you might as wheel i have all the tools to do it without taking the knuckle off!
Old Sep 1, 2006 | 01:43 PM
aligned, no more aggressive clicking, must of been rubbing. i still hear something when i turn the wheels. might be cv joints?
Old Sep 1, 2006 | 06:02 PM
chrisw85's Avatar
i can get koyo front wheel bearings for about $46/ea for abs EG civics/DC2, and about $38/ea for NTN non-abs civics.
Old Sep 1, 2006 | 07:09 PM
Tad's Avatar
Tad
lift each corner, w/ tranny in neutral and brakes off.
grab ur tire and spin the wheel, spin freely?
also grab it and jiggle it, there shouldn't be any play up/ down at all.
I probably wouldn't worry about my wheel bearing if it passed those tests.
cv joints should have been replaced along with your axles.
Old Sep 2, 2006 | 11:17 AM
eklum's Avatar
Default Re: (Tad)
my car was doing the same thing and over time it got more and more violent , turned out my cv boots had a huge gash in it i got new axles for free so i put those in and problem solved.
nightrise420
Mar 15, 2007 10:35 PM
integra1020
11
Feb 20, 2006 02:56 PM
xprog1
Apr 17, 2004 10:31 AM
Slow Egg
Dec 19, 2003 07:52 AM
honda8882
Sep 13, 2002 10:57 PM
