Suspension & Brakes Theory, alignment, spring rates....
need advice to lower my car
Old Aug 21, 2006 | 07:51 AM
CivicHP's Avatar
Default need advice to lower my car
how much of a drop i would need to have 1 finger gap or less on a EJ1 with 15in wheels? i was thinking of going coilovers but if there are springs out there that will do that drop i will go with those any advice.
Old Aug 21, 2006 | 08:36 PM
accordtuner1996's Avatar
Default Re: need advice to lower my car (CivicHP)
for that severe of a drop you want to replace the springs and the shocks at the same time. I dropped my accord 1.5 in the rear and 1.75 in the front with H&R sports, but left the stock shocks on. Shocks were dead within 6 months. Rule of thumb: if you are increasing your spring rate ( getting lowering springs, which are stiffer) you must increase the rebound rate of the shock (get Konis). If you don't get new shocks, the springs bounce the hell out of the internals of the stock shocks, as well as bring the shock outside of its nominal operating travel. Koni's optimal operating range is the entire travel of the shock, and with the Yellow's adjustability, they can be tuned to correctly damper the motion of just about any spring.
mikeunreal2
Suspension & Brakes
Aug 8, 2006 07:25 PM
bmoua
Suspension & Brakes
Oct 18, 2005 04:35 PM
bearboy80
Apr 3, 2003 10:10 AM
jonoknut
Sep 8, 2002 07:24 PM
Integra187
Mar 26, 2002 07:38 PM
