BKR6ES-11 vs. bkr7es-11
running jdm b18c-r
anyways, i went to pepboys before and bought 98 itr copper plugs which were the BKR6ES-11
i was told this is causing me to not burn all of the fuel and losing power
i checked ngk website and their 01 itr copper were the BKR7ES-11. i think this is the plugs i should have been running all along.
will running the 6 cause problems instead of running the 7 on my jdm r?
The BKR7E-11 is one heat range cooler than the BKR6E-11.
I've been running BKR7E-11's back when I was 1.8 and now that I am 2.0 as well. Great plugs for the money.
I don't know what the S stands for in those part #'s, never heard of that specific plug.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kingb16 »</TD></TR><TR><TD CLASS="quote">running jdm b18c-r
will running the 6 cause problems instead of running the 7 on my jdm r?</TD></TR></TABLE>
Use which ever, they will both perform almost identical.
it shouldn't cause a problem untill you have massive upgrades. however, since the motor did come with the 7 heat range(1 step cooler from 6)... its best if you just stick back to the 7 heat range.
you'll know your plug is too hot when you start to misfire and such(especially if you have msd or any other high output ign)
the one you should get is the bkr7e11 <--notice how it doesn't have the s in it... meaning it is not a standard electrode. the bkr7e11 has a v grove(v power) as compared to a bkr7es11(s for standard)
there's a whole lot more that i can break down for you about ngk plugs... but for know, i think this is sufficient.
infulleffect
Dec 28, 2005 05:30 AM
peacexisxfree
Oct 31, 2005 07:13 AM
