dc5 wierd clutch noise???
Old Aug 20, 2006 | 11:36 PM
dc5tegk20's Avatar
Default dc5 wierd clutch noise???
so heres the deal
went to drive to work today and noticed a sqeeking noise around the time when i would accelerate from leaving a stop so i thought and worried about it at work and on the way home i pinpointed to when it happens... as im leaving the clutch out right as it disengages it makes kinda of a grindingish/ sqeekish noise ( sorry i cant really describe it ) now my car is brand new 7100 miles and ive only flat shifted it a couple times and generally dont tear the gears and clutch up too bad any thoughts???
Old Aug 21, 2006 | 12:35 AM
idc5yes's Avatar
i had this problem also, juss take it back to the dealer and they should take care of it...(under warrenty), something with the clutch master cylinder. might be low or somthing i forgot
Old Aug 21, 2006 | 12:53 AM
jsantosDC5's Avatar
i had that prob as well but on my es1...it would make a squeeky noise whenever i would press on the clutch...it might just be that you need to lube the gear on the engine(i honestly do not know what it is called...sorry)
Old Aug 21, 2006 | 06:28 AM
a2_DC5's Avatar
Default Re: dc5 wierd clutch noise??? (dc5tegk20)
that happened to me too....it happens at the point where u aLmost fuLLy Let out ur cLutch and the tranny connects to ur engine, I got so pissed wen I heard that after I noticed the noise came from my car, I intensionaLLy did it 3 times, and the noise showed up 3 times and it just went away (?)
Modified by a2_DC5 at 12:07 AM 8/23/2006
Old Aug 21, 2006 | 09:36 PM
cnyej1's Avatar
Default Re: dc5 wierd clutch noise??? (a2_DC5)
There is a TSB on this for the EP3's I imagine its the same part as the RSX. The master cylinder is squeaking. Honda will replace for free.
victor.m
Apr 4, 2009 09:19 PM
RemerLex11
Mar 30, 2005 10:10 AM
p1driftfiend
Dec 30, 2003 07:34 AM
geminis2k
Jan 28, 2003 02:20 PM
obsidianG35
Aug 10, 2002 01:09 AM
