What Camber kit? Barely Tucking...
I'm planning to drop my car so i can be barely tuckin into my fender on my 90 civic si. which type of front camber kit do you guys recommend me? thanks i need to find out quick. thanks again!
I got my alignment done, i'm still getting camber wear :-/ and i had my TOE set to ZERO.
I used a progress technology camber kit from andysautosport.com on my eclipse. I'm glad you posted this because i was wondering if u could really get by with just setting the toe to prevent tire wear. my common sense was saying no but i was a little hopeful
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R »</TD></TR><TR><TD CLASS="quote">Post your alignment print-out.
Also check your trailing arm bushings.</TD></TR></TABLE>
I agree with this post. Worn bushings and the uncontrolled alignment they cause are a serious concern for tire wear.
Having driven a little over 10k miles on a car with -4.75* of rear camber, on a rwd car, and not seeing any signs of "camber wear" in the back, I fully believe that toe (either static or dynamic) is the real cause of increased tire wear. Now, this car also has very shot steering rack bushings, resulting in quite a bit of dynamic toe changes (wanders everywhere), and I do have visibly increased wear on the front tires, but the rear tires look new. I should rotate them at some point...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TunerN00b »</TD></TR><TR><TD CLASS="quote">Having driven a little over 10k miles on a car with -4.75* of rear camber, on a rwd car, and not seeing any signs of "camber wear" in the back, I fully believe that toe (either static or dynamic) is the real cause of increased tire wear. Now, this car also has very shot steering rack bushings, resulting in quite a bit of dynamic toe changes (wanders everywhere), and I do have visibly increased wear on the front tires, but the rear tires look new. I should rotate them at some point...</TD></TR></TABLE>
Gotta love old British cars with saggy springs
Now, this car also has very shot steering rack bushings, resulting in quite a bit of dynamic toe changes (wanders everywhere), and I do have visibly increased wear on the front tires, but the rear tires look new.</TD></TR></TABLE>
On my front wheel drive eclipse, the rear tires were the ones wearing out extremely fast and not the fronts. i thought it would have been the other way around. I am going to fix my complete suspension setup from now on including camber instead of just messing around with one thing at a time. it gets expensive testing different things to see what is causing the wear.
SiR Inspired ED7
Aug 20, 2006 08:54 PM
95slomocivi
Feb 23, 2006 03:48 PM
BADGUYNY
Oct 19, 2003 05:50 PM
