I have no pressure in my clutch pedal please help!!!!!
Old Aug 20, 2006 | 08:02 PM
EGG_y0's Avatar
Default I have no pressure in my clutch pedal please help!!!!!
Well i was just going to start my car. Car started fine i go to press in the clutch and it went stright to the floor.. i was like alright so i lifed it back up and it did it again. I have a 92 civic cx with a H22a1 with a H23 transwith a stage 3 clutch. I pretty much just got the car and i found out like maybe a month or so ago i was driving with out any fluid in my clutch cyclinder. So i go to fill it then like a week i check it and its gone. Then like 4 days after this happened.Please someone help me out thanks alot.
Old Aug 20, 2006 | 08:06 PM
Miracle's Avatar
Default Re: I have no pressure in my clutch pedal please help!!!!! (EGG_y0)
By what youre saying, it sounds like you have a leak somewhere. Check the master and slave cylinders, as well as the line input at the transmission for leakage. probably just some blown seals. Should not be a big thing.
Old Aug 20, 2006 | 08:23 PM
EGG_y0's Avatar
Default Re: I have no pressure in my clutch pedal please help!!!!! (Red_EM2)
but how could i have been driving w/o fluid for so long then all of a sudden it goes to the floor?
Old Aug 20, 2006 | 08:31 PM
graveltravel2's Avatar
why would you drive w/o fluid???? wtf....
sounds like to me the slave cylinder is shot.
Old Aug 20, 2006 | 08:33 PM
superacecardriver's Avatar
defenitly. replace the master cylinder and slave cylinder. Don't just replace one with out the other. Bleed the lines like you would a brake system. Having some pump the pedal or using a vacula if you have access to a compressor.
Old Aug 20, 2006 | 08:56 PM
FarinaMotorsports's Avatar
Default Re: (crx1.8)
Check where the master cylinder comes into the cabin through the firewall too, that's where mine was leaking and is a common spot. You can replace either the master cylinder or the slave cylinder seperately, both don't have to be changed at the same time.
Old Aug 20, 2006 | 09:03 PM
EGG_y0's Avatar
Default Re: (FarinaMotorsports)
how do i know which one to replace? just by which on is leaking?
Old Aug 20, 2006 | 09:13 PM
Default Re: (EGG_y0)
Yeah, just figure out which one is leaking and replace it. It could also be a line leaking so check them as well. The line leaking is not as likely though, as most of it is hardline.
Old Aug 20, 2006 | 09:30 PM
chrisw85's Avatar
with the cost of a slave cylinder at about $15, i dont see any reason why not replace it at the time of replacing the master cylinder? A new m/c is about $35 from sanyco or coni-seal. I replaced both of mine at the same time since it was 'cheap' insurance' to eliminate both variables with one stone.
Old Aug 21, 2006 | 03:45 AM
Default Re: (chrisw85)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chrisw85 &raquo;</TD></TR><TR><TD CLASS="quote">with the cost of a slave cylinder at about $15, i dont see any reason why not replace it at the time of replacing the master cylinder? A new m/c is about $35 from sanyco or coni-seal. I replaced both of mine at the same time since it was 'cheap' insurance' to eliminate both variables with one stone.</TD></TR></TABLE>
smart man.
Old Aug 21, 2006 | 07:17 AM
EGG_y0's Avatar
what sites did u get the slave and master cyclinder from?
Old Aug 21, 2006 | 07:28 AM
md88hfcrx's Avatar
btw: when you bleed the clutch line dont "pump" it, slowly depress and b4 it get the the floor tighten the bleeder valve. repeat many many times.
dont let it get to the floor with the bleeder valve open, or you start over again. i bled mine 2 days ago.
Old Aug 21, 2006 | 08:08 AM
Default Re: (md88hfcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by md88hfcrx &raquo;</TD></TR><TR><TD CLASS="quote">btw: when you bleed the clutch line dont "pump" it, slowly depress and b4 it get the the floor tighten the bleeder valve. repeat many many times.
dont let it get to the floor with the bleeder valve open, or you start over again. i bled mine 2 days ago.</TD></TR></TABLE>
wasn't implying to continue to pump the pedal. Just down once and it will stick to the floor the first few times, then open the screw then back up then down open repeat repeat repeat till all the air is out. Just trying to tell him its kinda the same conecpt as far as bleeding to get your clutch pedal back.
Old Aug 21, 2006 | 09:10 AM
EGG_y0's Avatar
so if there is nothing leaking then what could be wrong? i havnt looked at my car yet since its at my friends house
Old Aug 21, 2006 | 09:11 AM
turbociviccoupe's Avatar
just look at it first.
Old Aug 21, 2006 | 10:30 AM
chrisw85's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGG_y0 &raquo;</TD></TR><TR><TD CLASS="quote">what sites did u get the slave and master cyclinder from?</TD></TR></TABLE>
http://www.autohausaz.com they have the sanyco; sanyco manufactures many new hydraulic parts (brake m/c, clutch m/c slave cylinder wheel cylinders, they even make the hydraulics for stoptech) to many OE japanese companies. http://www.stopshopanddrive.com carries the same stuff, slightly different prices.
Old Aug 21, 2006 | 11:13 AM
del sol1658's Avatar
Not to highjack this thread, but i have the same problem. No pressure in my clutch, could this cause the clutch to slip?
Old Aug 21, 2006 | 04:53 PM
EGG_y0's Avatar
nice to know im not the only one right now with this problem and also before this happened i was having troble putting it into gear
Old Aug 22, 2006 | 08:35 AM
EGG_y0's Avatar
somebody mentioned that i could have broke my clutch cable? could this be why i have no pressure? and how hard is it to change?
Old Aug 22, 2006 | 05:28 PM
hydraulic clutch systems don't use cables.
eg6sittingon57cs
Aug 8, 2007 10:44 AM
bsixteen
Apr 17, 2005 04:06 PM
Phillip4285
Feb 1, 2005 07:05 AM
95civicracer
Aug 3, 2003 04:58 PM
Bklyn TSi
Oct 29, 2001 05:09 PM
