and Rolling fenders...
so my driver side front is rubbing the fender pretty bad. my suspension setup is neuspeed race springs with koni yellows and the wheels are ls mesh w/ 205/50/15 kumho asx. alll on a 99 hatch. anyone else with a similar setup have this problem? any reason y it only rubs on the driverside? would you suggest having the fenders rolled or getting new springs that aren't as low? perhaps the driver front spring or shock is dead? when i set the konis on stiff it doesnt rub as bad but ive got them on soft now to make the ride a little smoother.
reason it's only rubbing on the driver's side is b/c there's more weight on ur side since u're sittin on it. i would suggest gettin a new setup such as coilovers or if the budget doesn't allow that, roll ur fenders
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Danethomp »</TD></TR><TR><TD CLASS="quote">yea but even when im not in the car it seems to sit a bit lower...but i think some gc's might be in the mail soon
Um, the engine is on the driver's side of the car. Its the heavier side. Its also lower stock, but you can't tell with the stock 4x4 fender gap.
If you have a camber kit set to reduce front camber, then you're pushing the top of the tire further out, which would certianly contribute to rubbing. Add some camber to reduce or eliminate the rubbing.
If you don't have a camber kit, I'd recommend getting wheels with a higher offset, it sounds like the wheel is sitting too far out.
You can also raise the car up to the point where it won't rub.
</TD></TR></TABLE>Um, the engine is on the driver's side of the car. Its the heavier side. Its also lower stock, but you can't tell with the stock 4x4 fender gap.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TunerN00b »</TD></TR><TR><TD CLASS="quote">
You can also raise the car up to the point where it won't rub.</TD></TR></TABLE>
ive got an omni front camber kit, ls mesh wheels (not sure the offset), 205/50/15 kumho asx.i like the way it sits just wish it didnt rub may just have to raise it a bit w/ some coilovers.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast95eg8 »</TD></TR><TR><TD CLASS="quote">Does it rub on the inside or the outside area of the wheel well?</TD></TR></TABLE>
i have no idea.
i have no idea.
camber becomes negative not positive when a car is lowered
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by young noob »</TD></TR><TR><TD CLASS="quote">camber becomes negative not positive when a car is lowered</TD></TR></TABLE>
This is one of those points of confusion and always will be.
But what tunern00b means is to add (negative) camber. Generally when you "increase camber" you're making it more negative.
I know, i know, mathmaticians probably hate it.
BDogggUT34
Suspension & Brakes
Jan 9, 2007 09:16 AM
gambit1982
Nov 28, 2005 10:37 AM
rice_classic
15
Aug 26, 2002 06:39 AM
