custom shift light?
i want to use my stock rpm tack in my civic and i want to put a shift light custom mounted into a double gauge pod for the pillar some where but i was wondering if there is a way i can get the light to flash off of the stock rpm tack instead or have to get a after market rpm tack.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by usdm420 »</TD></TR><TR><TD CLASS="quote">they sell just shift lights for use with your stock tach....i'm sure you could custom rig it into a pillar pod if you really wanted to
yupper.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1990si »</TD></TR><TR><TD CLASS="quote">i have seen some hondas before that somehow wired there check engine light so it would come on at certain rpms.</TD></TR></TABLE>
or the abs light
</TD></TR></TABLE>yupper.
or the abs light
there's tuning software that can be used like CHROME for your ecu that has this function available
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B6tizzleHatch »</TD></TR><TR><TD CLASS="quote">my question is why?</TD></TR></TABLE>
Engine revs to 9000rpm, tach stops at 8000rpm. Drag racers use it to focus on the shifting and wait for the blinding light.
Also, some people like to think that it's a sign from god, a bright light, and he is sayign 'SHIFT YO!'.
you can get a "rpm activated switch". theyre popular with NOS kits. MSD sells a line of them. auto meter does too i think. summit has their own kit.
i had thought of using the turn signal lights in the stock cluster as a shift light. it wouldnt be hard to wire up. never bothered tho.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesrv »</TD></TR><TR><TD CLASS="quote">Engine revs to 9000rpm</TD></TR></TABLE>
thats all i needed to know
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesrv »</TD></TR><TR><TD CLASS="quote">Also, some people like to think that it's a sign from god, a bright light, and he is sayign 'SHIFT YO!'.</TD></TR></TABLE>
...ghey
...ghey
RiSiNgDc2
Mar 8, 2006 09:37 PM
Junkyard2000
Nov 13, 2005 04:06 PM
