USDM and JDM ITR manifold
Old Aug 20, 2006 | 05:28 PM
ED9man's Avatar
Default USDM and JDM ITR manifold
What are the differences between the two? What kinds of gains will I see versus the stock one? Do I need a 60 mm TB to get the most benefit? The stock first gen B16a one is a 58, all I have done otherwise is I/H/E. Thanks.
Old Aug 21, 2006 | 12:08 PM
ED9man's Avatar
bump
Old Aug 21, 2006 | 04:09 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: USDM and JDM ITR manifold (ED9man)
The USDM ITR uses a 62 mm (throttle plate) throttle body. The JDM ITR uses an even bigger throttle body (64 mm throttle plate if i recall correctly).
Old Aug 22, 2006 | 07:03 PM
ED9man's Avatar
I read something about different IACV's not being interchangable, would the IACV and other parts off my first gen B16a manifold work?
Old Aug 23, 2006 | 07:22 AM
ED9man's Avatar
If not, what car could I get an IACV from?
Old Aug 23, 2006 | 08:30 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: (ED9man)
You can check part numbers for compatability here:
http://www.acuraparts247.com
http://www.slhondaparts.com
HackeN
Jul 27, 2009 02:10 PM
ScorpioX
Mar 2, 2004 07:17 PM
Dirty GS-R
Sep 5, 2003 02:01 PM
se93
Jul 9, 2002 03:07 PM
