AC Not Working.
Old Aug 20, 2006 | 03:29 PM
NazVil86's Avatar
Default AC Not Working.
I was eating lunch and it was pretty hot outside- maybe 105*. So i leave, turn on my ac as usual and its blowing cold- as usual. I went to press the sunroof button, dont ask, and accidnetly hit the cruise control button than turned it off instantly. Ever since that my ac isn't blowing cold. I checked all fuses that could somehow be related. I searched and came up with checking the heater valve cable but i have no idea where that is located. I dont think it needs freeon since it was blowing really cold right before it went out. any ideas?
Old Aug 21, 2006 | 07:58 PM
jjyellow's Avatar
Default Re: AC Not Working. (Carnage86)
Does your compress still kick on when you turn it on
Old Aug 22, 2006 | 07:50 PM
naksukow's Avatar
all the more reason to take it out. . . save yourself about 30 pounds and it'll cost you nothing
Old Aug 23, 2006 | 08:10 AM
NazVil86's Avatar
Default Re: (naksukow)
wanna come down to texas and drive a car with no ac, a black car with no ac, in about 100degree wether and the humidity...i'll stop there. I just wanna get it fixed- its my daily driver- i aint about to save weight on the thing.
Old Aug 23, 2006 | 10:00 AM
Chuckles99SH's Avatar
Default Re: (Carnage86)
I would first start with easy things, like checking to see if your belt isn't slipping or anything like that.. then move on to things like is my compressor cycling on/off or not turning on at all.. if those come up working as intended, take it to a shop and have them check your ac system's pressure for the R134.. they might need to do a vaccum test and a recharge.. good luck Pvt. Cowboy
Old Aug 23, 2006 | 12:13 PM
NazVil86's Avatar
Default Re: (Chuckles99SH)
checked the ac components, belt is spinning, compressor seems to be working, fan is turning on when the ac button is pressed. I checked one of the lines towards the front passenger side to see if there was any freeon flowing through, it was empty. Can freeon run out in a split second? ive had an ac slowly stop cooling, but this just stopped so fast. anyways taking it tomorrow. hope they dont rip me off- since ac is in high demand when the temp is constant 95 or higher
Old Aug 23, 2006 | 01:07 PM
snowblind7x's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Carnage86 &raquo;</TD></TR><TR><TD CLASS="quote">checked the ac components, belt is spinning, compressor seems to be working, fan is turning on when the ac button is pressed. I checked one of the lines towards the front passenger side to see if there was any freeon flowing through, it was empty. Can freeon run out in a split second? ive had an ac slowly stop cooling, but this just stopped so fast. anyways taking it tomorrow. hope they dont rip me off- since ac is in high demand when the temp is constant 95 or higher</TD></TR></TABLE>
could have possibly sprung a leak i guess and drained it all out. I just had to get my AC fixed and had all the same things working you mentioned to and still had to end up 1) getting a leak fixed. 2) replacing the AC pressure switch. 3) replace AC pressure switch relay. 4) replace AC expansion valve and 5) add more freon. I ended up paying like 500 bucks in parts and labor to fix all this I sincerely hope yours doesn't turned out as fucked as mine did. Good luck.
Old Aug 24, 2006 | 10:31 AM
NazVil86's Avatar
Default Re: (snowblind7x)
thanx lol.
Killtodie
Honda Civic (2001 - 2005)
23
Sep 4, 2007 12:57 AM
crazyguy
Jul 25, 2007 02:27 PM
Demon R
May 23, 2004 10:46 PM
See Are X
Apr 19, 2002 09:49 PM
