H22 leaking oil from sensor in back of block
Old Aug 20, 2006 | 01:34 PM
jdmcd7_cali-luv's Avatar
Default H22 leaking oil from sensor in back of block
Has any one else encountered this problem before?
There is what looks like an oil sending sensor on the back
of the block that has a slow leak. It leaks directly onto the headers.
I tried to loosen it but it was too tight, dont know what to do.
Any help would be appreciated
Old Aug 20, 2006 | 02:29 PM
Eddiebx's Avatar
sounds like the oil pressure switch. sometimes they break and leak internally, so u might need a new one. u can try and take out the switch and reseal the threads to see if that helps. or u can just get a new one, they are not too expensvie, like 25ubcks or so i think.
Old Aug 20, 2006 | 02:51 PM
hondadude's Avatar
Default Re: H22 leaking oil from sensor in back of block (JDMCD6_Cali-Luv)
very common problem, best thing is to replace it. 24 mm socket will fit it.
Old Aug 20, 2006 | 03:52 PM
Default Re: H22 leaking oil from sensor in back of block (hondadude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondadude &raquo;</TD></TR><TR><TD CLASS="quote">very common problem, best thing is to replace it. 24 mm socket will fit it.</TD></TR></TABLE>
24mm, thanks!
Old Aug 20, 2006 | 11:26 PM
iam7head's Avatar
24mm DEEEEEEEEEEEEEEEEP socket
let's hope it's the sensor not the housing, the housing are known to crack and leak all over the place if you overtighten it, or by adding stress to it(brass tee's for turbo oil juice )
put tape on the thread before you but it back
PinkMaggit
May 21, 2008 12:47 PM
h22_crx
Jan 19, 2007 03:06 PM
djnikko
Oct 3, 2006 04:49 PM
93CharcoalHatch
Jan 6, 2006 09:42 AM
IH82LOSE
Oct 3, 2003 01:54 PM
