how would i make an Obd0 to obd1 jumper harness
Old Aug 19, 2006 | 08:34 PM
Nightkidef9's Avatar
Default how would i make an Obd0 to obd1 jumper harness
Like the title says, i want to save some money and make my own jumper harness. I have a p28 ecu with 6 inches of harness still attached. Is there any How-to guide so i dont eff something up?
Old Aug 19, 2006 | 09:15 PM
hatchinprogress's Avatar
Default Re: how would i make an Obd0 to obd1 jumper harness (Nightkidef9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nightkidef9 &raquo;</TD></TR><TR><TD CLASS="quote">Like the title says, i want to save some money and make my own jumper harness. I have a p28 ecu with 6 inches of harness still attached. Is there any How-to guide so i dont eff something up?</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=1510399
https://honda-tech.com/zero...age=1
Old Aug 19, 2006 | 09:41 PM
downest's Avatar
Default Re: how would i make an Obd0 to obd1 jumper harness (hatchinprogress)
HA! Just posted this in another thread, from my SOHC VTEC build guide:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">
&gt;&gt;&gt;&gt;Building the Conversion Harnesses&lt;&lt;&lt;&lt;
It's possible to use an SAFC unit or an RPM switch to acctivate the VTEC. I chose not to do this, I wanted to install the entire thing like it was meant to be done, with factory connectors and run the motor on and OBD1 P28. I also tried to make everything easily removable, I plan on getting another CRX soon and I want to be able to put this one back to stock and swap my motor over to the new car. So before you even touch the car, get all the wiring ready, it will reduce downtime. All connections should be soldered, with heat shrink over the joints. When you are done and know everything works (ie running the car) then go ahead and tape it all to make it look pretty.
First off you want to make the dizzy conversion harness. Go to a junkyard and cut off the harness side plug for the dizzy you are using. In my case this was a D16Y7 dizzy from a 98 Civic CX. It would be ideal to cut the dizzy side plug from an OBD0 car, but I couldn't find one. I decided to solder into the main harness because I didn't have another choice, and it's only 9 wires so it's easy to return to stock. Basically you just need to match colours, here are OBD0, OBD1, and OBD2 dizzy wire colours and functions, these are all verified by me after hours of verifying and checking, don't trust every post you read on Honda Tech! This wiring kept me hung up for a week getting no fuel, but I got straightened out by Ryan (the Ry in Rywire).
OBD0 OBD1 OBD2 Function
Orange Orange Yellow CYP P
Small White White Black CYP M
Orange/Blue Orange/Blue Green TDC P
White/Blue White/Blue Red TDC M
Blue/Green Blue/Green Dark Blue CKP P
Blue/Yellow Blue/Yellow White CKP M
Large White Yellow/Green Yellow/Green ICM
Black/Yellow Black/Yellow Black/Yellow IGN
Blue Blue Light Blue RPM
For the ECU conversion (you don't need this if you are already OBD1, or aren't converting) you need to get the ECU and some length of harness to work with. I pulled a P28 from a 92 EX at the yard, and instead of unclipping the harness I just cut a good length of wires to go with it. I got a junk OBD0 ECU from a friend (these should be free, don't ever pay for a PM5!) and removed the plugs by pulling it apart and desoldering them from the board. Now all you need to do is connect the wires.
For OBD0, the big, 18 pin connector is A. The other two are sort of connected, the first 20-pin one is B and the last one, 16-Pin, is C. For OBD1, They read A B D, A is the largest, a 26-pin connector, B has 16 pins, and D has 22.
The numbers are read this way: Looking at the plug on the wire side, as if it were plugged in, the top left is 1, and below it is 2, next to it is 3. So, odd numbers run across the top and evens across the bottom. It gets a little tricky doing this since you are looking at different sides of the two types of plugs, so be very careful and work slowly. If you need to, put a little masking tape to mark the plug numbers.
Here is the conversion, I skipped unused plugs.
OBD0 Function OBD1 Function
A01 INJ1 A01 INJ1
A02 PG1 A23 PG1
A03 INJ2 A03 INJ2
A04 PG2 A24 PG2
A05 INJ3 A05 INJ3
A06 PCSol A20 PCSol
A07 INJ4 A02 INJ4
A11 EACV A09 IACV
A12 FLR1 A07 FLR1 (Main Relay)
A13 IGP1 A25 IGP1 (MR/resistor box)
A14 FLR2 A08 FLR2
A15 IGP2 B01 IGP2
A16 GND B02 LG2
A18 GND A26 LG1
B01 VBP/Hazard D01 VBU/Hazard
B03 ACC A15 AC Clutch
B04 FANC A12 FANC
B05 ALT A16 ALT
B06 MIL A13 MIL (CEL)
B08 ACS B05 AC Sw
B10 CYP P B11 CYP P
B12 CYP M B12 CYP M
B13 Fusebox B09 Starter
B14 ALT D09 ALT
B15 Ignition A21 ICM
B16 VSS B10 VSS
B17 Ignition A22 ICM
B19 ELD D10 ELD
B20 SCS D04 SCS
C01 CKP P B15 CKP P
C02 CKP M B16 CKP M
C03 TDC P B13 TDC P
C04 TDC M B14 TDC M
C05 IAT D15 IAT
C06 ECT D13 ECT
C07 TPS D11 TPS
C10 BKSW D02 (Brake Switch)
C11 Mil GND (MAP) D17 MAP
C12 SG2 D22 SG2
C13 VCC1 D19 VCC1
C14 SG1 D21 SG1
C15 VCC2 D20 VCC2
C16 O2Sensor D14 PHO2sensor
You will have a few wires left on the OBD1 plugs. You need to run 3 of these into the engine bay. I soldered them onto a plug close to the harness so I could pull the harness out of the car without a long wire running to the plugs.
A04 goes to the VTEC solenoid
A06 goes to the O2 sensor
D06 goes to the VTEC pressure switch
Everything else left on the harness is for things like Automatic transmission and EGR. If you got a harness from an EX manual (where the P28 came from) you should be all set here.
Now, you need to take a break and do something else. Before you put this thing in, you need to check it at least once for continuity. DO NOT just follow the wires, you need to make sure all the connections are good. Take a break in between checks, or have someone else do it, it's very easy to make mistakes. Don't tape it all up until you run the car with it!
Last thing is the O2 sensor wiring. Now, you don't need to go to a 4-wire O2 sensor for OBD1, as long as you keep the sensor in the stock position on the manifold, on the front of the motor. I made the mistake of trying to use the 1-wire on my DC header, where it's located behind the motor. It's better to just get a 4-wire heated O2 sensor in the first place, and you won't be throwing a code 41.
The sensors all seem to have different colours. I used a Bosch universal 4-wire for a civic, and it came with a piece of paper that listed the colours and what their functions were. To avoid confusion I'll use letters.
So you will have 1 colour A wire, 1 colour B wire, and 2 colour C wires. A will be ground and B will be signal, while C is for the heating element. Put the ground to the thermostat ground, if your sensor is behind the motor it's convenient. Splice the signal (B) into the old single wire that was running to the original O2 sensor. The two Cs are non-polar, the heater doesn't need to be in a certain direction. Run one to pin A06 (should be one of your extra wires on the harness), and the other to an ECU power yellow/black wire, I used B01 (OBD1 side), you'll need to tap into it. I would suggest using some kind of quick release connectors for these, so you can take the exhaust out without removing the sensor. Don't solder it together and leave the sensor hanging there while you are going to be installing the motor or head, you could easily break it.
Old Aug 20, 2006 | 06:53 AM
cbp_crx's Avatar
Default Re: how would i make an Obd0 to obd1 jumper harness (downest)
damn thats a good write up
Old Aug 20, 2006 | 07:36 AM
downest's Avatar
Default Re: how would i make an Obd0 to obd1 jumper harness (cbp_crx)
Thanks, I've given it out like 5 times in the last 2 days. I also have a PDF version of the whole OBD conversion and mini-me build/swap with pictures and everything.
Old Aug 20, 2006 | 07:40 AM
dr_latino999's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by downest &raquo;</TD></TR><TR><TD CLASS="quote">Thanks, I've given it out like 5 times in the last 2 days. I also have a PDF version of the whole OBD conversion and mini-me build/swap with pictures and everything.</TD></TR></TABLE>Showoff....I just have a bunch of letters and numbers in a thread.....
Old Aug 20, 2006 | 07:42 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by downest &raquo;</TD></TR><TR><TD CLASS="quote">Thanks, I've given it out like 5 times in the last 2 days. I also have a PDF version of the whole OBD conversion and mini-me build/swap with pictures and everything.</TD></TR></TABLE>post pics if you can (it will probly help out other's as well)
Old Aug 20, 2006 | 07:52 AM
downest's Avatar
Default Re: how would i make an Obd0 to obd1 jumper harness (dr_latino999)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote">Showoff....I just have a bunch of letters and numbers in a thread..... </TD></TR></TABLE>
I used your thread to make my harness, but it was such a pain to find every time for some reason because of the subject/title. It is 100% right though!
I don't know how pics will help for the conversion harness... for the build maybe.
Old Aug 20, 2006 | 12:06 PM
I don't know how pics will help for the conversion harness... for the build maybe.</TD></TR></TABLE>my bad..yeah i ment the build
Old Aug 20, 2006 | 04:23 PM
thanks brothers, this will be my labor day project.
Coke in a Can
Mar 6, 2008 02:55 PM
4drferio
Jun 18, 2007 08:03 PM
CR-V-tech
10
Jan 16, 2006 06:21 PM
specv5150
Nov 19, 2005 08:14 PM
ace1875
Apr 24, 2004 06:43 AM
