yes another timing question duhh
ok i have a built y7 does it have the same timing issue as the y8 ..? or can it handle more timing under boost.. im running a p2p map 12 deg base and set at 12 on the dizzy... how much timing are u running on ur y7's .. i have it at 11.75 at 14 psi is this too much or too little .. till i get tuned i wanna know and can i go higher so i can tell my tuner to make some hp by turning it up
non --vtec all the way
fast2camciv
Sep 1, 2006 06:56 PM
