carbon fiber hood has dents can! how to fill in and paint?
Old Aug 19, 2006 | 06:15 PM
LagunaSecaEG's Avatar
Default carbon fiber hood has dents can! how to fill in and paint?
i bought a carbon fiber hood from jdmsh*t and after a few months it had like 3 dents in it. Then after a few more months it had 6 dents in it.I was just wondering if u can fill these dents in and paint over it? and how would i do so?
Old Aug 19, 2006 | 06:50 PM
itsjdmbradyo!'s Avatar
Default Re: carbon fiber hood has dents can! how to fill in and paint? (LagunaSecaEG)
im not too sure carbon fiber can dent.
Old Aug 19, 2006 | 07:03 PM
DUFFM4N's Avatar
Default Re: carbon fiber hood has dents can! how to fill in and paint? (itsJDMbradyo!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itsJDMbradyo! &raquo;</TD></TR><TR><TD CLASS="quote">im not too sure carbon fiber can dent.</TD></TR></TABLE>
it usually happens during production not EVERY carbon fiber hood is perfect
jdmshit hoods have a layer of fiberglass first i believe then a layer of carbon fiber over that. but mine has dents in it.keep in mind this hood is 4 years old
Old Aug 19, 2006 | 07:05 PM
DUFFM4N's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LagunaSecaEG &raquo;</TD></TR><TR><TD CLASS="quote">jdmshit hoods have a layer of fiberglass first i believe then a layer of carbon fiber over that.</TD></TR></TABLE>
...like ALL carbon fiber hoods
Old Aug 20, 2006 | 06:50 AM
Default Re: carbon fiber hood has dents can! how to fill in and paint? (DUFFM4N)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DUFFM4N &raquo;</TD></TR><TR><TD CLASS="quote">
...like ALL carbon fiber hoods</TD></TR></TABLE>
I thought it was a fiberglass skeleton and carbon fiber over that. Thats how fiber images hoods are. When you pop the hood you can see the sunlight through the weaving. I should have been more specific. Cheap hoods like mine have the fiberglass skeleton and a layer of giberglass then carbon fiber on top?
I dont know I could be wrong but anyways, could you fill the dents in with resin? then sand them till they are smooth? i just want to paint the hood the same color as my car
Old Aug 20, 2006 | 07:50 AM
carbonall's Avatar
* B A N N E D *
I dont know I could be wrong but anyways, could you fill the dents in with resin? then sand them till they are smooth? i just want to paint the hood the same color as my car</TD></TR></TABLE>
nope, fiberimages have a fiberglass skeleton and a fiberglass skin with a layer of carbon fiber over that. This is the industry standard. Carbon fiber hoods are only 10% carbon and the rest is fiberglass and resin. a lot of carbon fiber hoods coming out now are NOT CARBON FIBER, but dyed fiberglass and sold as carbon fiber. You can see through the weaving because they did not paint the underneath like ViS and Seibon does. If you are going to paint just smooth them with bondo and paint.
Old Aug 20, 2006 | 08:22 AM
E46Kid's Avatar
Default Re: carbon fiber hood has dents can! how to fill in and paint? (carbonall)
Paint a carbon fiber hood the same color as your car?? goodluck hopefully your painter is good, CF stretch's and can cause bubbles and look nasty
Old Aug 20, 2006 | 08:33 AM
carbonall's Avatar
* B A N N E D *
it is not the carbon fiber that does that. The carbon is under the surface not on top. Alot of carbon hoods use gel coat. The same thing that is on the surface of most body kits. You just sand it down like normal and make sure to use a poly primer. If it is a clear coat surface then you can use normal primers and such
Old Aug 20, 2006 | 05:59 PM
ITR EG's Avatar
Default Re: (carbonall)
My JDMSH!T hood got dents too. I got sick of it and sold it.
Old Aug 21, 2006 | 04:41 PM
Default Re: (ITR EG)
i called them and told them it happened like 4 months after i got it and they are like send us pictures and we can send u a new one. and its kind of hard to send pictures of a hood that has dents in it. i had a shitty camera
Old Aug 21, 2006 | 05:00 PM
carbonall's Avatar
* B A N N E D *
what brand was it?
Old Aug 22, 2006 | 02:05 PM
im not sure but jdmshit.com sells them. they talked so highly of the hoods and it was a nice hood untill 4 monhts down the road.
hot_kenneth_hot
Honda S2000
14
Jun 9, 2006 02:54 PM
2006PwPDc5
May 13, 2006 03:15 PM
red civic standard
Feb 25, 2005 12:17 PM
eg6nes
Jan 13, 2005 09:34 AM
civic-si-2000
Jun 11, 2003 11:02 AM
