idle hates me.
Old Aug 19, 2006 | 05:05 PM
Phshorty's Avatar
Default idle hates me.
ok guys i know i could go search for this but after 6 pages i just quit. ok my ide started surgeing when i was stoped at a light and now it does this every time. it goes from about 900rpms where it normaly sits, to 1800-2000rpm then back down then revs up again.. someone tryed to race me at a light because of this if you guys could eather point me to the right post or at the sensor or what ever is doing this. picture or location sumthing. thanks again guys.
Old Aug 19, 2006 | 05:07 PM
pandarex's Avatar
Default Re: idle hates me. (Phshorty)
usually when this happens its a vacuum leak, check or replace your hoses.
Old Aug 19, 2006 | 05:09 PM
Phshorty's Avatar
Default Re: idle hates me. (pandarex)
all my hoses and cooling lines and wires are all new. i had a vacume leak befor and your idel stays high, it didnt surge like it is now. up then down, up then down, up then down.
Old Aug 19, 2006 | 05:22 PM
SVOboy's Avatar
Last time I had a vacuum leak it surged just like that,
Old Aug 19, 2006 | 05:23 PM
george34's Avatar
Make sure the coolant is bleed well. I have heard that air in the coolant lines can cause problems like yours.
Old Aug 19, 2006 | 05:27 PM
B16-CRX's Avatar
unplug your throttle position sensor while it idles bad. if it goes away you need a new tps. Ive also heard about air in the coolant.
Old Aug 19, 2006 | 05:36 PM
blumpfish's Avatar
Default Re: (B16-CRX)
clean your throttle cable, easy way to check if its sticking is when it happens pull back on the pedal and see if it goes back to normal idle
Old Aug 19, 2006 | 05:42 PM
X-Static's Avatar
agreed, good chance its a vacuum line...its happened to me the same way several times...check all the vacuum connetions coming from the back of the intake manifold
Old Aug 19, 2006 | 05:44 PM
DC_RaceR's Avatar
Default Re: idle hates me. (X-Static)
Check you IAVC...
Old Aug 20, 2006 | 04:34 AM
Phshorty's Avatar
ok thanks guys im going to check these things out and get back to you.
honcrf150
13
May 29, 2012 10:28 AM
nekoabandoned
13
Feb 12, 2006 12:52 PM
civiclxb16a
11
Apr 27, 2005 06:20 PM
team2n1hatch
10
Apr 2, 2003 03:32 PM
chirp2hrd
19
Sep 19, 2002 09:24 PM
