1998 honda prelude
Old Aug 19, 2006 | 02:21 PM
djcue_530's Avatar
Default 1998 honda prelude
im haven some trouble starting my car..i check everything..but ive been reading that it can be my fuel relay, maybe it can be bad...but not sure about that...the car will crank..everything sounds normal, it cranks and everything but it wont turn on..and also i found gas like look on my spark plugs..i know it aint engine oil..cuz its to thin to be it and different color and also the smell..it smelt like gas...is that bad?...i need help asap..its my only car to ride....so if theres any help out there plz help me..thank u
Old Aug 19, 2006 | 02:22 PM
mkazm83's Avatar
Default Re: 1998 honda prelude (djcue_530)
Maybe you flooded it?
Old Aug 19, 2006 | 02:24 PM
djcue_530's Avatar
Default Re: 1998 honda prelude (mkazm83)
so then what do i need to do??...what the best thing?
Old Aug 19, 2006 | 02:39 PM
mkazm83's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djcue_530 &raquo;</TD></TR><TR><TD CLASS="quote">so then what do i need to do??...what the best thing?</TD></TR></TABLE>
http://en.wikipedia.org/wiki/Flooded_engine
Old Aug 19, 2006 | 02:42 PM
djcue_530's Avatar
READ THIS....SOME GUY WROTE THIS ON A TOPIC ON SOMEOTHER WEBSITE..
WHAT DO U THINK ABOUT IT?...ANY BETTER WAY?...OR EASIER WAY..BETTER EXPLANATION TO IT? AND ALSO I HEARD HONDAS ALWAYS HAS A FLOODING PROBLEM..WHAT DO I DO?
Do the standard checks. Check for spark. Check for fuel. If you have spark & fuel pull the plugs and check to see if they are fouled. Try new plugs. Use NGK plugs. When these cars sit for awhile they have a common problem of flooding themselves. If when you are trying to start the car it sounds like it has no compression (turns over real fast). Pulls the plugs and disable the dist. then crank the car over to clear the engine flood, reinstall the plugs, then try to start normally, if it doesn't start right away try holding the gas pedal to the floor while crancking over the engine (sometimes this may take awhile). If the previous doesn't work sometimes you have to pinch off the fuel pressure line to the injectors then try to start, this is a 2 man job. Good Luck !!!
Old Aug 19, 2006 | 02:52 PM
djcue_530's Avatar
HEY THANXS BRO...THAT WEBSITE U GAVE ME WORKED..I JUST WENT OUTSIDE AND TRYIED IT..I TOOK OFF MY AIR FILTER AND LEFT IT OPEN AND HELD THE GAS PEDAL ALL THE WAY IN AND CRANKED IT FOR A BIT TILL IT TURNED ON..I TRYED IT LIKE 3 TIMES AND THE 3RD TIME IT TURNED ON :D..THANX..NOW FOR SURE ILL BE BACK FOR ANY HELP
Old Aug 19, 2006 | 03:21 PM
mkazm83's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djcue_530 &raquo;</TD></TR><TR><TD CLASS="quote">HEY THANXS BRO...THAT WEBSITE U GAVE ME WORKED..I JUST WENT OUTSIDE AND TRYIED IT..I TOOK OFF MY AIR FILTER AND LEFT IT OPEN AND HELD THE GAS PEDAL ALL THE WAY IN AND CRANKED IT FOR A BIT TILL IT TURNED ON..I TRYED IT LIKE 3 TIMES AND THE 3RD TIME IT TURNED ON :D..THANX..NOW FOR SURE ILL BE BACK FOR ANY HELP</TD></TR></TABLE>
Cool.
And for future reference, don't type in all caps.
Old Aug 20, 2006 | 12:31 PM
djcue_530's Avatar
my car wont start again..i think my engine keeps flooding?..what do i do if it keeps flooding..cuz everytime i try to start it..it hella smells like gas is getting burnt, but the car will not start still..it will continue to wanna crank on but nuthing. any help on this?
Old Aug 21, 2006 | 10:47 AM
djcue_530's Avatar
anyone?....my engine keeps flooding....what do i do in order for it not to be doin that..do i need to buy a new part??what goin on...I NEED HELP!
petrolio
Jan 9, 2008 04:22 PM
GageRawqs
Mar 31, 2007 06:44 PM
BDRphaSe2
Jan 14, 2006 10:18 AM
Stage587
Jun 12, 2005 02:28 PM
teamCSR_prez
Mar 2, 2005 06:25 PM
