anyone shorten there stock shifter?
Old Aug 19, 2006 | 01:56 PM
CRX MASE's Avatar
Default anyone shorten there stock shifter?
im thinking about cutting 2 inches off my stock shifter and rethreading it, and putting on a skunk2 ****, anyone else done this to there crx? Im just trying to get some ideas. I just want a shorter shifter not a shorter throw. PICS would be great
Old Aug 19, 2006 | 02:00 PM
extensioncordy's Avatar
i did it in my EG , my buddy did it in his GTI. its not a bad thing to do. i dont have any pics. but id say go for it
Old Aug 19, 2006 | 02:07 PM
SIred91's Avatar
Rainman
Default Re: anyone shorten there stock shifter? (CRX MASE)
why do you want to rice out your shifter and make it even harder to hit fifth gear from a comfortable seating position than it already is?
lame...
Old Aug 19, 2006 | 02:18 PM
CRX MASE's Avatar
Default Re: anyone shorten there stock shifter? (SIred91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIred91 &raquo;</TD></TR><TR><TD CLASS="quote">why do you want to rice out your shifter and make it even harder to hit fifth gear from a comfortable seating position than it already is?
lame... </TD></TR></TABLE>
because the stock shifter is uglyas hell, and how would you consider that rice? maybe i should put on a neon shift ****
Old Aug 19, 2006 | 02:27 PM
downest's Avatar
I did it on my old one, feels much better and less like a UPS truck.
Yeah... umm how is that rice? Also, how is it harder to get it into 5th, you do realise that the top of the **** would actually be CLOSER right?
Old Aug 19, 2006 | 02:29 PM
EnSAn's Avatar
Default Re: anyone shorten there stock shifter? (downest)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by extensioncordy &raquo;</TD></TR><TR><TD CLASS="quote">i did it in my EG , my buddy did it in his GTI. its not a bad thing to do. i dont have any pics. but id say go for it</TD></TR></TABLE>
How short are you? and that's not rice. Now if he runs some flashing LEDS to that **** then we can call it rice. my 2 pennies
Old Aug 19, 2006 | 02:53 PM
Mr.Death's Avatar
Default Re: anyone shorten there stock shifter? (EnSAn)
I trimmed a couple inches off of my stock shifter abd love it.
Old Aug 19, 2006 | 03:51 PM
CRX MASE's Avatar
Default Re: anyone shorten there stock shifter? (Mr.Death)
looks good guys, can you guys give me some tips on how you did it?
Old Aug 19, 2006 | 04:18 PM
FernEF's Avatar
^^ take a saw and just cut
Old Aug 19, 2006 | 04:40 PM
CRXBart's Avatar
I'm running the BC short shifter unit for an EP3 Hatch.
It is shorter throw, and comes with a 2" extention. I have since removed the extention, and like it better. I personally don't like short shifters I like the shifter as close to the wheel as possible. IF you are using a conventional rod shifted tranny. Look into the Fastline Performance Shifter:
The closer it is to the wheel the faster you can get to it and select another gear. Thats the thinking behind it. After driving mine for a few day, I love it and am contemplating buying a fastline for my beater.
Old Aug 19, 2006 | 05:20 PM
downest's Avatar
Default Re: anyone shorten there stock shifter? (CRXBart)
So Bart, is it a total bitch to get the center console out with that thing or what?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX MASE &raquo;</TD></TR><TR><TD CLASS="quote">looks good guys, can you guys give me some tips on how you did it?</TD></TR></TABLE>
It's easy to do...
First you need to get 2 dies for the threads, a coarse one and a fine one, you will also need a plastic bag, tape, oil, and a hacksaw.
Begin by pushing the bag over the shifter, so it punches through, and then tape it around the base of the shifter. This will keep metal pieces and oil off the boot and the car.
You need to look up or test what size die to use, I forget what it was, but I remember I found how to do the whole thing through a friend on his accord forum (all honda shifters are the same threading). Remove the **** and spin the coarser die down the existing threads. The coarser one will cut the unthreaded metal easier.
Get a little oil on there to lube it up, and start turning, backing off every once in a while to clear the cuts, and of course re-oiling.
You will be able to get about 2 inches or so before it gets REALLY difficult, due to the increased diameter of the shifter. Take the die off and then go over it with the finer one, so now you will have uniform threads all the way up.
Leave the die on the bottom of the threads and cut off as much as you want. It's important to leave the die there so it will clean up the threads after you cut.
Spin the die off, clean up, and install the ****.
Old Aug 19, 2006 | 06:02 PM
crxblues's Avatar
it makes no sense having the shifter that close to the steering wheel for daily driving unless u only drive with both hands on the wheel
Old Aug 19, 2006 | 07:45 PM
Tippyman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXBart &raquo;</TD></TR><TR><TD CLASS="quote">I'm running the BC short shifter unit for an EP3 Hatch.
LIAR! Didn't you sell that ****?
Old Aug 19, 2006 | 09:17 PM
hatchinprogress's Avatar
Default Re: anyone shorten there stock shifter? (Tippyman)
i bought my hatch with the shifter already shortened (sorry no pics) people think it looks good, and i have no problem shifting (i like it)
Old Aug 20, 2006 | 03:28 AM
CRXBart's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by downest &raquo;</TD></TR><TR><TD CLASS="quote">So Bart, is it a total bitch to get the center console out with that thing or what?
No just put it in 2-4-6-R and it pops right out around it. I still need to fab my trim panel for it though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman &raquo;</TD></TR><TR><TD CLASS="quote">LIAR! Didn't you sell that ****?</TD></TR></TABLE>
LOL
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxblues &raquo;</TD></TR><TR><TD CLASS="quote">it makes no sense having the shifter that close to the steering wheel for daily driving unless u only drive with both hands on the wheel</TD></TR></TABLE>
I don't daily drive the car, but I do always drive with both hands at 10 and 2 for optimum control. It took some getting used to, but it is definitly the way you should grip the wheel for a reason. Try it for awhile you'll like it.
Old Aug 20, 2006 | 04:03 AM
W O T's Avatar
Barts got the right idea actually, might not look the best, but for downshifting or if your car actually makes enough power that 2 hands on the wheel AS MUCH AS POSSIBLE makes the car easier to handle ( I know my 312whp scoots me around on the road) then its a good thing
I personally cut my stock shifter ealier this season and hated how low it was, I actually went back to stock with a 3" extension when I put my tranny in, its just so much more comforatable
Old Aug 20, 2006 | 07:15 AM
downest's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXBart &raquo;</TD></TR><TR><TD CLASS="quote">No just put it in 2-4-6-R and it pops right out around it. I still need to fab my trim panel for it though. </TD></TR></TABLE>
I meant the FL shifter
Old Aug 20, 2006 | 07:17 AM
CRXBart's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by downest &raquo;</TD></TR><TR><TD CLASS="quote">I meant the FL shifter</TD></TR></TABLE>
They are 2-peice the top unscrews.
Old Aug 20, 2006 | 07:53 AM
downest's Avatar
Do they make a boot for it?
Old Aug 20, 2006 | 08:04 AM
saikouEF8's Avatar
get a b&m straight short shifter and a real 5 spd type r ****. it sits low enough. i know what your looking for.
Modified by saikouEF8 at 10:17 AM 8/20/2006
Old Aug 20, 2006 | 08:21 AM
downest's Avatar
Default Re: anyone shorten there stock shifter? (saikouEF8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by saikouEF8 &raquo;</TD></TR><TR><TD CLASS="quote"> i know what your looking for. </TD></TR></TABLE>
creepy.
Old Aug 20, 2006 | 10:30 AM
CRX MASE's Avatar
creepy.</TD></TR></TABLE>
lol
Old Aug 20, 2006 | 10:32 AM
b18CrxSi91's Avatar
71.179.86.205
because the stock shifter is uglyas hell, and how would you consider that rice? </TD></TR></TABLE>
Because its gay...
Old Aug 20, 2006 | 01:38 PM
downest's Avatar
Default Re: anyone shorten there stock shifter? (b18CrxSi91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18CrxSi91 &raquo;</TD></TR><TR><TD CLASS="quote">Because its gay... </TD></TR></TABLE>
Way to back it up. Again, how is it rice?
What if I use a hacksaw and die set that's made in Japan? Would that make it JDM and not rice (cause there IS a difference)?
Old Aug 20, 2006 | 01:43 PM
LShatchboy's Avatar
Yeah, its "gay" to cut your shifter to make it more comfortable... WTF is wrong with some of you guys? I am starting to wonder..... All of the sudden EVERYONE wants stock honda OEM wheels, stock cd players, and now cutting a shifter is rice? screw that idea. Do what YOU think looks good and dont listen to people that say "that is gay" gosh, what a GREAT comeback.
Oh and yes, use JDM tools, way cooler.. JDM, USDM, makes NO difference. The only hting better about JDM is the engines IMO.
