Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
k24 automatic
Old Aug 19, 2006 | 01:54 PM
shevlin's Avatar
Default k24 automatic
has any one swaped an automatic k24 into their automatic chassis i was just curious what would be different than a manual k swap, and what was done about the wiring, thanks.
Old Aug 19, 2006 | 01:57 PM
Miracle's Avatar
Default Re: k24 automatic (shevlin)
Not really practical if you ask me. But you can do some good numbers with the automatic I assume.
But if yo are going to swap a K into the EM2, Id go manual. More powerpotential, less maintenance, more fun to drive, and cheaper in the long run if you tear something up in the process.
Old Aug 19, 2006 | 11:41 PM
shevlin's Avatar
Default Re: k24 automatic (Red_EM2)
wow, that didnt answer my questions thanks.
Old Aug 20, 2006 | 05:18 AM
toyomatt84's Avatar
Sanji
I'm unsure of anyone having a K24 automatic. I've only seen a few instances of K24's all together, and they've all been manual transmissions. I don't know what all you're thinking for the car, but if you want to do an automatic, you might be forced into using the EP3 transmission, unless you swap out to 5-bolt hubs.
Old Aug 20, 2006 | 07:42 AM
fventura03's Avatar
why would you want to swap an automatic tranny? that's for wimps/girls.
the answer is yes. has anyone been dumb enough to do it? no. when/if you do it, you'll probably run in to some problems because it wont be documented anywhere on the web which line goes to which.
i dont even know if kpro works with an auto tranny, i believe someone did it for their base auto rsx. ask "stOOpid" about that one he made it work.
Old Aug 20, 2006 | 09:50 PM
fg2si!kid's Avatar
New User
one thing about auto is that if something gos bad in their its going to cost you for repairs and if you do it your self but have no clue on how to start your in for a whole new world with all them clutch packs planitary gear sets its just a big mess plus you will most likely need some special tools also if you plan on heavy mods to the engine you will need to beff up the outo tranny with like a shift kit amd better cluches and so fourth, and i dont evan think they whould make something like that for our cars my opinion just stick with a manual trans
...hope this helps ..
vinceg143
May 3, 2009 01:42 AM
addiction2bass
11
Jul 23, 2008 03:57 PM
stock96accordlx
Dec 1, 2007 08:14 PM
Reis
Jul 13, 2005 12:42 PM
ericjackson
Jun 21, 2005 01:52 PM
