Leaking Water under car by tranny
Old Aug 19, 2006 | 12:02 PM
k_lude's Avatar
Default Leaking Water under car by tranny
My H22 hatch is leaking some water from the side where the Tranny is it does leak alot but wheres the water pump on the h-series?
Old Aug 19, 2006 | 12:24 PM
Buffalo's Avatar
Default Re: Leaking Water under car by tranny (k_lude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k_lude &raquo;</TD></TR><TR><TD CLASS="quote">My H22 hatch is leaking some water from the side where the Tranny is it does leak alot but wheres the water pump on the h-series?</TD></TR></TABLE>
on the other side...
check any radiator hoses for leaks
Old Aug 19, 2006 | 01:13 PM
k_lude's Avatar
Default Re: Leaking Water under car by tranny (Buffalo)
yeap checked...no leaks....any other problems that might cause this??
Old Aug 19, 2006 | 01:26 PM
prelude1897's Avatar
Do you use your A/C? If so, that's what it is. The water pump is on the driverside of the motor where your T-belt is
Old Aug 19, 2006 | 04:07 PM
madcatz's Avatar
I agree with stoopid here
taste it....if its water, its your AC Condencer (sp)
if its anything else, well I hope you dont die
Old Aug 19, 2006 | 05:17 PM
k_lude's Avatar
Default Re: (madcatz)
NO AC...its in a hatch....
Old Aug 19, 2006 | 07:51 PM
mgags7's Avatar
theres no magical water source on the car dude, its either leaky radiator hoses or you have little water-laden elves trekking all over the passenger side of your engine bay and merrily spilling water all around to confuse you
Old Aug 20, 2006 | 07:05 AM
lude98SH's Avatar
Default Re: (mgags7)
what color is the fluid ? if you know what color that will help you destinguish alot
Old Aug 20, 2006 | 08:12 AM
Default Re: (lude98SH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lude98SH &raquo;</TD></TR><TR><TD CLASS="quote">what color is the fluid ? if you know what color that will help you destinguish alot </TD></TR></TABLE>
+1
Old Aug 20, 2006 | 11:16 AM
Buffalo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">theres no magical water source on the car dude, its either leaky radiator hoses or you have little water-laden elves trekking all over the passenger side of your engine bay and merrily spilling water all around to confuse you</TD></TR></TABLE>
THE NINJA WATER
EFlovin'
Jul 31, 2012 01:39 AM
Adankid
27
Jul 31, 2008 10:20 PM
greasemonkee
Nov 24, 2006 01:22 PM
intezn
Apr 4, 2003 09:20 AM
