JDM GSR Swap into and LS...distributor wiring help needed
Friend of mine put an OBD1 JDM GSR swap in his LS.
The harness he's using appears to be a USDM vtec OBD1 harness.
The distributor has two plugs off it, while the harness only has the one large one. The harness has 8 wires into the clip. The distributor has 7 wires one on clip, and 2 on the other.
I was hoping someone had some information on how I can wire this up for him. I checked c-speed and did some thorough searching on here and have been unlucky so far. TIA
The best solution would be to get a obd1 wiring(with the 2 plug) if the car is obd1 or a obd2 distributor if the car is obd2 but if you want to go ahead and chop the plug here is the diagram !
Edit : you may not have the wire for the rpm lead on your wiring !
Modified by teg xsi at 5:16 PM 8/19/2006
Modified by teg xsi at 5:17 PM 8/19/2006
egreenmachine
Feb 24, 2009 11:05 AM
civic00_dude
Sep 15, 2008 07:43 AM
Patrickchampagne2006
Mar 21, 2007 02:35 PM
