Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Pioneer NAV install, need speed sensor wire location.
Old Aug 19, 2006 | 06:31 AM
enabi's Avatar
Default Pioneer NAV install, need speed sensor wire location.
Has anyone here installed an aftermarket navigation unit ? If so, It would help me out a great deal if you could give me an ECU pinout diagram or just a wire color/location for the speed sensor line going to the ecu. I dont want to run my line all the way to the engine bay. Thanks in advance.
Old Aug 19, 2006 | 01:30 PM
KJMRide's Avatar
Default Re: Pioneer NAV install, need speed sensor wire location. (enabi)
The computer is in the engine bay. The only other place you can get it in the car is at the guage cluster. Let me know what the model is (si on not) and ill give you the wire info.
Old Aug 19, 2006 | 03:15 PM
Turbo(less)DB8's Avatar
i've installed a ton of the pioneer nav units and most are accurate enough where a speed sensor is not completely necessary. try it without. it'll work fine.
Old Aug 19, 2006 | 03:51 PM
enabi's Avatar
Default Re: Pioneer NAV install, need speed sensor wire location. (Turbo(less)DB8)
Its an LX model, coupe. So far it looks like the setup is working without it, but I havent driven the car yet. There is also some kind of engine readout display with a speedometer and tach, both of which are greyed out and have a "not available" written over them. Im guessing the speed sensor hookup would fix this.
Old Aug 21, 2006 | 03:51 PM
KJMRide's Avatar
in the 06civic manual it is connector A(44 pin conector) at the PCM(The first connector at the ECU) it is pin 29, it is a blue wire. Be careful though the tach wire is right next to it and it is also blue (kinda stupid but I didnt make the car) The pin next to it is blank if that helps.The numbering is like this. / / / 4 5 6 / 8 9
10 / / / 14 15 16 17 18 19
20 21 22 ----------23 24 25
26 27 28 29 / 31 / 33 34 35
36 37 / 39 40 41 42 / 44
Termanal side of the female terminals.
Old Aug 21, 2006 | 03:53 PM
KJMRide's Avatar
Default Re: Pioneer NAV install, need speed sensor wire location. (KJMRide)
sorry the post moved the layout of the pins let me know if you cant figure it out and ill sent you a pic.(I kinda figured that would happen)
Old Aug 22, 2006 | 03:52 PM
enabi's Avatar
Thanks for the info, I will give it a shot this friday.
Old Aug 23, 2006 | 09:18 AM
06techcivic's Avatar
Default Re: (enabi)
A speed sensor wire is located in the main harness of the stereo. It is a blue wire. We have it there because of the speed sensitive volume that our stereos have. Anyway hope that helps. I have mine hooked up there and it works great.
Kory
Old Aug 23, 2006 | 08:41 PM
Forklift352's Avatar
witch pioner do you have?
Old Aug 24, 2006 | 01:38 PM
enabi's Avatar
Default Re: (Forklift352)
Speed sensitive Volume.... ok. The head unit is a N3 model.
Old Mar 8, 2008 | 09:42 AM
surfnxs's Avatar
I am installing a pioneer avic system in a honda odyseey. Do you have the vss wire location for a 2000 odyseey? I found it listed as a blue and white wire behind the center console. I found one, but would appreciate a pin diagram etc. before I chance it.
Any help would be appreciated.
Thanks,
Old Sep 12, 2021 | 11:38 AM
Michael Torres's Avatar
I need help with knowing where the speed sensor wire location on the radio harness is there so many harnesses in this 2015 Civic Si w\o Nav let me know I'm having some real trouble and after I've installed everything my cruise control don't work no more when i push the cancel or down button the rpms stick goes up but nothing happens to the engine stays the same it doesn't start rev. I need some im trying to connect the HDCC-02 and the ASWC-1 to the radio harness.
foxdecoy
Aug 21, 2009 03:41 PM
LaEzEnT
Dec 15, 2008 07:50 PM
rnbguy
Oct 25, 2008 10:36 AM
sohcvtec1995
Sep 11, 2003 12:10 PM
