No Spark....Can you help me?
I've got no spark on my '90 Civic Hatch. I changed everything.....Cap, rotor button, wires, ignitor, module, main relay and I even changed the computer. All the fuses are good, and as far as I know the connections are good. Other than a broken wire in the harness, do you any guys have any Idea what it could be?
Timing belt?
Have you pulled the cap off to crank it and see if it is spining?
I would try to swap out the entire distrubitor as well like gmctruck suggested.
Grounds?
Check all your grounds?
Whater are you checking for spark...from the cap or from the wires? Maybe bad wires.
Grounds?
Chrisbequick
Oct 16, 2008 07:39 PM
