89 crx wont start! help!
Old Aug 18, 2006 | 06:04 PM
vinnyknock's Avatar
Default 89 crx wont start! help!
Ok here we go! my 89 honda crx will not start! this began when i was driving up a hill my car lost all power bogged out and died! now i checked the fuel rail and it is recieving fuel the fuel pump kicks on and the car turns over and the plugs have spark! however i am not recieving any fuel to the plugs! i diagnosed the problem and realized that all of my injectors were reading 10 milivolts when they should be reading 12 volts while the key is in the on position! now i thought at first it was the ECU well i replaced that and the car still didnt start! so i moved on to the injector transistor( the grey box tucked by the wheel well on the right side if your looking at the motor) replaced that and the car still doesnt start! im stumped and i dont know were to go next so if any of you guys can help me out id greatly appreciate it! (all fuses are fine! it is a 1590cc 1.6L 4 cyl vtech sohc with fully bored pistons rebuilt motor and cold air intake!) please any information will be appreciated !
Old Aug 18, 2006 | 06:10 PM
SiR Inspired ED7's Avatar
Default Re: 89 crx wont start! help! (vinnyknock)
Check your MAIN RELAY, Prolly took a ****.
Replace it or, clean and re soldier all connections...
Old Aug 18, 2006 | 07:26 PM
Tippyman's Avatar
Check that your rotor button is connected properly. happened to me twice!
DaveTheMedic
16
Jan 22, 2019 12:07 PM
baldmofo
Oct 19, 2006 08:13 AM
22psicrx
10
Sep 11, 2006 08:49 PM
88hondaef
Aug 28, 2006 10:58 AM
SRCivic97
Oct 22, 2004 05:27 PM
