TONS OF PARTS!!!! SHOP CLEAN UP!!
OK so I decided I was tired of everything being a mess so I cleaned it all up and its all organized. I've typed up about a 1/4 of the stuff and if you want to take the time to look through the list feel free to PM me if you see anything you need. Majority is DSM & Honda parts.... I will update list as soon as I get everything typed up.
MAKE OFFERS!!!
• (3)DSM Main Caps
• (2)DSM Water Pump Pulley
• DSM Front engine bracket
• B series water pump
• VTEC exhaust cam
• Colt rear mount
• D series driver side engine bracket
• (2) Honda fuel feed line
• Colt main relay
• CTR Piston and Rod
• PR3 Piston and Rod
• DSM crack pulley
• Honda power steering bracket
• D15 Crack pulley
• DSM turbo outlet elbow
• DSM turbine housing clamp
• (4) DSM pistons
• OBD1 distributor (missing parts)
• DSM valve cover
• B series cable tranny mount
• Honda brake master cylinder
• DSM power steering bracket
• Honda B series throttle body
• Civic CRX corner lense driver side
• B series driver side mount
• DSM fuel rail w/ regulator
• DSM water pump
• DSM clutch master cylinder
• OBD1 distributor cap
• OBD0 distributor cap
• DSM fuel rail w/ injectors
• OBD0 distributor-incomplete
• 96+ civic driver side bracket
• D series rear engine bracket
• 1g throttle body elbow
• (2) DSM upper thermostat housing
• BNM DSM fuel pressure regulator
• (3)DSM oil caps
• DSM clutch fork with throttle bearing
• Honda map sensor
• Negative battery cable
• DSM water pump (dirty)
• D16Y8 flywheel dust cover
• DSM front engine bracket
• D series tranny mount
• DSM rear engine bracket
• DSM water pipe
• (2)Honda fuel feed line
• DSM crack pulley
• (2) D series driver side mount
• (2) DSM fuel pump
• DSM fuel rail
• (2)DSM starter
• Honda map sensor external mount
• D series rear tranny mount
• B series tranny bracket passenger side
• (2) Integra front tranny mount
• DSM o2 sensor
• D series cam gear
• D series oil pump
• B series throttle body
• OBD0 Honda fuel rail- b series
• 95+ eclipse driver side mount
• DSM
• D16 cam
• DSM timing belt tensioner
• (4) D16a piston and rod
• Honda 4wire o2 sensor
• D series lower alternator bracket
• (2) Honda IAC valves
• OBD1 driver side engine bracket
• 90-93 integra rear bracket
• Honda FPR
• GSR T.B.
• OBD1 distributor SOHC
• D16Y7 T.B.
• PR3 cam gear
• Honda tps
• Honda pcu valve
• H22 drivers side mount
• H22 drivers side bracket
• H22 balance shaft sprocket
• D sheries front mount
• (2) OBD1 b series distributor
• OBD1 B series fuel rail
• OBD0 B series fuel rail
• GSR TB bracket
• DSM 2g o2 sensor housing
• F22 distributor
• 90-93 integra tranny bracket
• DSM lower thermostat housing
• (2) Honda fuel feed lines
• Honda fuel filter w/ line
• Civic/crx battery tray
• DSM speedo cable
• Colt/Mirage tranny mount
• OBD1 SOHC fuel rail
• 90-93 integra driver side mount
• 94+ integra rear bracket
• OBD2 Distributor (SOHC)
• OBD0 SOHC starter
• DSM rear bracket
• B series PS Pump
• OBD2 bseries alternator
• T3 compressor housing
• OBD1 distributor cap (b series)
• OBD0-1 Alternator
• Honda OBD0 B series TB
• OBD0 D real brace
• OBD0 D side mount
• 4G63 crank pulley
• (2) 4G63 fuel rail
• 4G63 alternator
• (2)Honda hydro clutch lines
• Honda slave cylinder
• 4G63 90 TB
• 4G63 tranny bracket
• OBD1 B series distributor
• OBD0 D-series driver side mount
• 4G63 FPR
• 4G63 turbo outlet elbow
• OBD0 B series TB
• Honda resistor box
• Rising FPR
• OBD0 B series TB
• Honda OBD0 Alternator B series
• OBD2 B series alternator
• Honda starter
• B series OBD1 TB
• 4g63 cam angle sen. 91+
• (2) OBD1 distributor caps (b series)
• (2) OBD0 rear bracket
• H23 distributor
• (2) OBD1 distributor B series
• Distributor D series
• (2) 4g63 starters
• 4g63 wastegate actuator
• OBD1 94+ integra rear bracket
• B series oil pump
• OBD1 d series distributor
• OBD0 MSD distributor cap B series
• OBD0 B series TB
• Honda fuel feed line
MAKE OFFERS!!!
• (3)DSM Main Caps
• VTEC exhaust cam
• Colt rear mount
• Colt main relay
• DSM crack pulley
• D15 Crack pulley
• (4) DSM pistons
• DSM valve cover
• DSM water pump
• (3)DSM oil caps
• Honda map sensor
• DSM water pipe
• DSM crack pulley
• (2) DSM fuel pump
• DSM fuel rail
• (2)DSM starter
• DSM o2 sensor
• D series cam gear
• D series oil pump
• DSM
• D16 cam
• Honda FPR
• GSR T.B.
• D16Y7 T.B.
• PR3 cam gear
• Honda tps
• Honda pcu valve
• GSR TB bracket
• F22 distributor
• DSM speedo cable
• OBD0 SOHC starter
• DSM rear bracket
• B series PS Pump
• OBD0-1 Alternator
• OBD0 D real brace
• OBD0 D side mount
• 4G63 crank pulley
• 4G63 alternator
• 4G63 90 TB
• 4G63 FPR
• OBD0 B series TB
• Rising FPR
• OBD0 B series TB
• Honda starter
• B series OBD1 TB
• H23 distributor
• (2) 4g63 starters
• B series oil pump
• OBD0 B series TB
LilLowEK
12
Sep 17, 2012 08:51 AM
NotAJDMFanBoy
Jun 26, 2011 09:30 PM
NycCTR
Sep 14, 2010 07:09 AM
