Does the Window regulator have any gears?
Old Aug 18, 2006 | 04:22 PM
diyer's Avatar
* B A N N E D *
Default Does the Window regulator have any gears?
Vehicle: 1994 Honda Accord Ex, 4 dr.
Are there gears I can lubricate in the door/window regulator. I have the interior paneling off and cannot see any gears anywhere. Other cars have them.
Old Aug 18, 2006 | 05:44 PM
philadd's Avatar
Default Re: Does the Window regulator have any gears? (diyer)
You won't see any. 5th gens use a wire system to raise and lower the window. You can try lubing the tracks that the wire slides through...
Old Aug 19, 2006 | 02:35 AM
iam7head's Avatar
Default Re: Does the Window regulator have any gears? (philadd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philadd &raquo;</TD></TR><TR><TD CLASS="quote">You won't see any. 5th gens use a wire system to raise and lower the window. You can try lubing the tracks that the wire slides through...</TD></TR></TABLE>
cable motor that expance or compact the slider, there's a track with gear on it.
most of the time, the shop/previous owner use the wrong type of lude, the wrong type of grease baked up and jam the track, try some carb/intake clearner on the gear/tooth, clean it up a bit and then use the right grease.
Old Aug 19, 2006 | 08:26 AM
diyer's Avatar
* B A N N E D *
Default Re: Does the Window regulator have any gears? (iam7head)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iam7head &raquo;</TD></TR><TR><TD CLASS="quote"> ... "most of the time, the shop/previous owner use the wrong type of lude" .... </TD></TR></TABLE>
I agree. I found out that with other vehicle window mechanisms I have lubed that the softer multi-purpose greases work much better. Thanks
Btw, where is the gear tooth, can you give me a hint? I have the Helms manual. is the location shown in it?
littlemoule
Apr 13, 2016 11:50 PM
Gsr94black
Feb 23, 2012 06:15 AM
david90
May 31, 2004 08:01 AM
weakGOODJunKieS.com
Audio / Security / Video
Jul 23, 2003 11:44 PM
swtcivic93
Jun 18, 2002 10:12 PM
