Squealing From Wheel well
Old Aug 18, 2006 | 03:50 PM
C_R_X_V_T_E_C's Avatar
Default Squealing From Wheel well
When i back my car out of the driveway, there is a squealing noise from the wheel well, only in reverse though not in first 2nd 3rd ect... it has new pads & rotors, if it was the drivetrain it would squeal both forward and reverse..... so if anyone has any suggestions let me know..... Thanks
Old Aug 18, 2006 | 08:07 PM
synergy10's Avatar
Default Re: Squealing From Wheel well (C_R_X_V_T_E_C)
Sounds like a problem I had when I did my brake job. Try using some fine sand paper on the rotors. The noise is probably coming from the build up of your brake pad residue.
HTH!
Old Aug 18, 2006 | 08:49 PM
B6tizzleHatch's Avatar
Default Re: Squealing From Wheel well (synergy10)
take the pads off and clean the rotor and pads, then go from there, mine had some built up dirty/mud that dry'd while my car sat for a weekish. clean em both and go from there? keep us updated
Old Aug 19, 2006 | 03:14 PM
Default Re: Squealing From Wheel well (B6tizzleHatch)
I fixed the problem.....
It turned out to be a pebble was stuck between the rotor & the sheild so it was only rubbing in reverse because going forward put a flat spot on the rock and when it tried to go backward it was the rotor rubbing on the pebble. thanks for the ideas and feedback..........
The Guy.
B_Swapped93
May 31, 2013 02:21 PM
Xathine
Mar 15, 2009 10:03 AM
nomoreavril
Dec 13, 2006 02:47 PM
kimota
Sep 26, 2005 01:23 PM
dclub01
May 28, 2003 08:51 AM
