B-series motor built for SFWD
block: b18b1
darton sleeves stepdecked and bored to 81mm by exospeed racing
custom JE pistons 9.5:1(b16/ITR head)
eagle (big bolt) rods
lined bored and fully balanced by DG motors
ACL bearings
I can assemble for an additional fee
zero miles since rebuild
$1800
head:
JDM ITR
stock ports
hottanked
stock sized ferrea stainless steel valves
skunk valvetrain
shaved Edebrock intake manifold
edebrock 75mm throttle body
all sensors and distributor
shaved valve cover
prepped for LS/vtec
skunk2 cam gears
$1800
stock obd2 GSR transmission. 5th gear is pops out$400
used gator stage 3M axles for B-series hydro with brand new intermidiate shaft$650
OS Giken twin disc clutch/flywheel setup for B-series hydro. Used for 400 miles and 0miles since rebalanced$750
brand new bosch 044 fuel pump(355lph) $240
If you buy all of these together, I can knock off some loot as well. I need to get rid of these ASAP because I am totally broke and I'm sick of looking at these things not going to good use.
ACL bearings
$1800
head:
JDM ITR
stock ports
hottanked
skunk valvetrain
shaved valve cover
prepped for LS/vtec
skunk2 cam gears
$1800
asubennett
Feb 15, 2006 03:47 PM
