clutch cables doesn't fit on b16a please help!!!!!!!!!!!!!!!
Old Apr 25, 2002 | 06:14 PM
ef civic's Avatar
Default clutch cables doesn't fit on b16a please help!!!!!!!!!!!!!!!
my stock cable won't fit and i bought a 90-93 integ cable and that doesn't fit 2 please post some picks and info thanks
Old Apr 25, 2002 | 06:57 PM
EP3_05's Avatar
Default Re: clutch cables doesn't fit on b16a please help!!!!!!!!!!!!!!! (ef civic)
I used the stock one on my swap. Try this...disconnect the cable from the pedal and then connect it to the assembly on the transmission. Now try to hook it back up to the pedal. HTH
Old Apr 25, 2002 | 07:34 PM
-TJ's Avatar
-TJ
Default Re: clutch cables doesn't fit on b16a please help!!!!!!!!!!!!!!! (91civic)
You need to shorten the jacket on your cable. See a picture of what to do here:
In the event that picture doesn't show up, read for the link to the picture here, it's in the section titled "Clutch Cable Problems?"
http://tjshondas.20m.com/b16ainstall.html
-TJ
Old Apr 25, 2002 | 07:36 PM
Count Blah's Avatar
From: A place where stupidity runs rampant aka NorCal
Default Re: clutch cables doesn't fit on b16a please help!!!!!!!!!!!!!!! (-TJ)
90 integra clutch cable works fine, you must be doing something wrong. Just did one on a S1 tranny in a 89 crx last week.
-Todd
Old Apr 25, 2002 | 07:56 PM
slim's Avatar
New User
Default Re: where?
anyone have a pic of where you cut exactly?
Old Apr 25, 2002 | 08:21 PM
......'s Avatar
I used a 93 int gsr cable
Old Apr 25, 2002 | 08:40 PM
flat-blk-HB's Avatar
your stock cable should work i used my DX cable on my LS swap and it worked out fine.
Old Apr 25, 2002 | 08:54 PM
Rocket's Avatar
Default Re: clutch cables doesn't fit on b16a please help!!!!!!!!!!!!!!! (89EF-BCUMBIE)
What clutch do you have and what throw bearing are you using?
Old Apr 25, 2002 | 09:15 PM
-TJ's Avatar
-TJ
Default Re: clutch cables doesn't fit on b16a please help!!!!!!!!!!!!!!! (Rocket)
The EF cable wil work unmodified, but you max. out the adjustment trying to get the clutch release point right and even then you won't be sure that the PP is fully seating with all it's available pressure. In other words, it may be like driving around with your foot resting on the clutch pedal.
Old Apr 25, 2002 | 11:50 PM
ef civic's Avatar
i got a act 6 puck clutch
Old Apr 26, 2002 | 12:44 AM
E-lude78's Avatar
go to Acura or a junkyard and get the clutch cable bracket off of a USDM 90-93 integra tranny then use the integra cable you already have
Old Apr 28, 2002 | 03:25 AM
Rocket's Avatar
Default Re: clutch cables doesn't fit on b16a please help!!!!!!!!!!!!!!! (Mista B-one-seven)
I had the same problem once and had to shorten the cable housing by cutting it with a dremel.
A different brand of throw out bearing may give you more clearance.
Good luck.
Old Apr 28, 2002 | 06:40 AM
SiR Kid's Avatar
New User
I never disconnect my cable from the clutch pedal, and to get the cable to go back on the bracket correctly under the hood, I use a jack and a ball joint seperator to jack up the clutch arm outside the tranny, to allow the cable to be put into place on the bracket... I know it's kinda dangerous, but getting under the dash is annoying
Anyone else ever do this?
Nathaniel Corum
Nov 2, 2014 01:52 PM
ryanevansoh
Mar 23, 2009 02:02 PM
BlakeJ53
Sep 30, 2007 05:59 AM
wrXtian
21
Aug 4, 2005 07:59 PM
Dosvita
Mar 20, 2005 03:01 PM
