Brake help - searched
Old Aug 18, 2006 | 12:10 PM
Scott (T.O.A)'s Avatar
Default Brake help - searched
Hi there,
basically i just brought a ED9 (civic 1.6 i-16 d16) , its been sat for a while but i knew the car before standing and its good all rounder! basically the only problem with it is that the brakes arnt very good.
by this i mean they are very soft, they dont seem to work until about 3/4 of the way down. the pads need changing (which is getting done tomorrow) but the disks seem fine.
ive bled the brakes (allbeit just the front ones as the back nipples are seized on and dont look like they are coming off) (and i have all round disks as standard btw, not sure if you got the i-16 in the usa) and still not much difference.
when the engine isnt running and the servo isnt working the pedal is hard as a rock, its just when the servo starts it go's soft as hell.
ive read that alot of these problems are to do with master cilinders, any ideas?
thanks
scott
P.s would the rear calipers off a Ef vti be a str8 swap for the calipers on my ED9?
Old Aug 18, 2006 | 11:35 PM
bump any ideas?
Old Aug 20, 2006 | 02:59 PM
someone has got to know! any help would be very much appriciated!
Old Aug 26, 2006 | 08:02 AM
Ned UK's Avatar
its actully an ED7 Scott
Old Aug 26, 2006 | 04:25 PM
JimBlake's Avatar
Default Re: Brake help - searched (Scott (T.O.A))
I'd bleed them again. Get some penetrant (Liquid Wrench or???) soaking in the rear bleeders for a day or 2 & try them again.
Every time I've tried to bleed 'only' the corners that need it, I never get away with it. Gotta bleed all 4.
With a bad master cylinder, the pedal will be solid at first, but if you hold the brakes for a couple minutes (red light) it will slowly, smoothly, sink to the floor. That doesn't sound like your description.
Mr.Cheezil
Jul 4, 2012 10:24 PM
95sivee
11
Jul 10, 2006 08:14 PM
Jdm 98spec R
Sep 9, 2004 06:20 AM
99SlammedCivic
21
Apr 12, 2004 07:47 AM
yusoslo
Oct 15, 2002 02:02 PM
