line lock question on stock brake system
Old Aug 18, 2006 | 10:28 AM
b18ccivics's Avatar
Default line lock question on stock brake system
i was thinking about installing a line lock to the rear wheels, and use the stock prop valve, but there is 2 lines going to the rear and i have read that the prop. valve divides the fluid on diagionals. so do i have to buy 2 line locks or can i just tee the 2 rear lines together then go threw the line lock and tee back off to the rear brake calipers? thanks
Old Aug 19, 2006 | 08:23 AM
b18ccivics's Avatar
Default Re: line lock question on stock brake system (b18ccivics)
nobody knows
Old Aug 19, 2006 | 08:54 AM
antireversion's Avatar
not sure what the prop valve looks like but cant you put the LL inline before the prop valve? Am I right in assuming the prop valve has one line in and two out?
Old Aug 19, 2006 | 09:06 AM
ciscoscivic's Avatar
1 line-lock install line-lock on main feed line for rear brakes.
Old Aug 19, 2006 | 03:22 PM
b18ccivics's Avatar
Default Re: line lock question on stock brake system (ciscoscivic)
which one feeds the rear, isnt honda prop valve divide the fluid on diagionals, the line coming from the rear port on the master cylinder feed the front right wheel and the rear left wheel, and the front port on the master cylinder feed the front left and the rear right. am i wrong? that is just what i have read and that is what it looks like but dont know the internal passages of the prop. valve. can
Old Aug 19, 2006 | 04:31 PM
underpressure02's Avatar
I would like to know also. I will be installing mine soon. Any pics.
Old Aug 19, 2006 | 05:23 PM
DaveF's Avatar
Default Re: line lock question on stock brake system (underpressure02)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by underpressure02 &raquo;</TD></TR><TR><TD CLASS="quote">I would like to know also. I will be installing mine soon. Any pics. </TD></TR></TABLE>
you are retarded AHAHHAHAAHAHHA you got anymore room left in your car with them 20,000 gauges AHAAHAHAHHAAHHAHA
Old Aug 19, 2006 | 07:28 PM
b18ccivics's Avatar
Default Re: line lock question on stock brake system (dturbocivic)
are the 20000 gauges under the hood? if they are he may not have room
Old Aug 20, 2006 | 04:22 AM
DaveF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18ccivics &raquo;</TD></TR><TR><TD CLASS="quote">are the 20000 gauges under the hood? if they are he may not have room</TD></TR></TABLE>
10,000 are under the hood
Old Aug 20, 2006 | 06:22 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">
you are retarded AHAHHAHAAHAHHA you got anymore room left in your car with them 20,000 gauges AHAAHAHAHHAAHHAHA</TD></TR></TABLE>
dick
kantspell
Sep 30, 2011 07:53 AM
porkchop3xpress
Suspension & Brakes
Jul 17, 2010 04:43 PM
Dublin
Oct 14, 2007 06:48 PM
wantboost
Welding / Fabrication
17
Nov 18, 2005 08:33 PM
misledyouth
Jan 29, 2003 11:08 AM
