Maxbore throttle body
Old Aug 18, 2006 | 10:04 AM
InvaderTrax's Avatar
Default Maxbore throttle body
Just got my throttle body and intake manifold back from maxbore.com. For $160, my TB was cleaned and bored to 64mm, and the opening of my intake manifold was ported to match. The TB bore is very smooth and clean, as is the intake. Very pleased with the work. Although I only picked up about 5hp, I've gained a lot of throttle response
Old Aug 18, 2006 | 10:25 AM
Jago's Avatar
Default Re: Maxbore throttle body (InvaderTrax)
yes maxbore does good work
Old Aug 18, 2006 | 10:35 AM
John.'s Avatar
Default Re: Maxbore throttle body (Jago)
only 5hp? dude every little bit counts...
Old Aug 18, 2006 | 10:36 AM
ninja 6's Avatar
jeez that fast idle thermo valve looks rusted like ****...
but the tb looks good
the lining looks very thin and brittle seeming though...
Old Aug 18, 2006 | 11:08 AM
ShinobiLude's Avatar
Default Re: Maxbore throttle body (fish stick)
The idle thermo looks WORSE on the second pic...which is funny. Looks good though...very clean.
Do you have a stock intake mani? and what are your mods?
Old Aug 18, 2006 | 01:31 PM
sivikvtec's Avatar
Default Re: Maxbore throttle body (ShinobiLude)
Is that real 5whp or "but dyno" 5whp?
Old Aug 18, 2006 | 02:04 PM
They're actually two different TB's (both from 92 H23's), which is why the the fast idle valve looks cleaner on the stock bore one. The one on the maxbore TB isn't rusted, it's muddy. The other one was corroded, so before I put it on (while the other one was away), I tried to polish it with the wire brush on my bench grinder
Old Aug 18, 2006 | 04:50 PM
.BigSexy's Avatar
most hood white kid
Default Re: (InvaderTrax)
are you happy with the purchase?
Old Aug 18, 2006 | 04:59 PM
Chief_Rocka's Avatar
looks good
Old Aug 18, 2006 | 05:01 PM
.BigSexy's Avatar
most hood white kid
Default Re: (egcoupe94)
what else will they do? port out the eintire IM? remove secondary butterflies? altough I want to keep mine, I want more air flow
Old Aug 18, 2006 | 05:47 PM
98vtec's Avatar
moderator emeritus
Default Re: Maxbore throttle body (sivikvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sivikvtec &raquo;</TD></TR><TR><TD CLASS="quote">Is that real 5whp or "but dyno" 5whp? </TD></TR></TABLE>
Old Aug 18, 2006 | 07:30 PM
Yes, I'm quite happy. All maxbore will do is TB and manifold openings. If you want your entire manifold ported, check out BlackTrax. As for power, I've seen plenty of dyno sheets that show a 5-8whp gain
Old Aug 18, 2006 | 07:36 PM
98vtec's Avatar
moderator emeritus
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by InvaderTrax &raquo;</TD></TR><TR><TD CLASS="quote">I've seen plenty of dyno sheets that show a 5-8whp gain</TD></TR></TABLE>
mind sharing some of these dyno sheets?
Old Aug 18, 2006 | 07:46 PM
If I knew where they were, I would. Some were on TV on assorted cars. I'll search around and see what I can pull up
Old Aug 18, 2006 | 07:51 PM
98vtec's Avatar
moderator emeritus
that would be great
Old Aug 18, 2006 | 08:02 PM
Sifted through many pages, and although I found a lot on big bore TB's on V8's, I couldn't find much useful to us. Closest I got was this quote for a 1.6L Nissan Sentra
"On the Dyno, the larger throttle body did not help the peak power more than 1 hp but kept the power curve flat across the top for 400 rpm and gave 2 more hp past the peak from 6300 to 7300 rpm. Now the power curve is virtually flat from 6000 to 7300 rpm with no more than 4 hp deviation! This is big fat useable hp, not like the peaky hp that Hondas typically have. An equivalently modified D series motor usually has a slightly higher but pointy power curve. This motor has a big fat slope that is flat across the top. Guess which motor is faster, the one with more area under the curve!"
Old Aug 18, 2006 | 10:24 PM
.BigSexy's Avatar
most hood white kid
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by InvaderTrax &raquo;</TD></TR><TR><TD CLASS="quote">Yes, I'm quite happy. All maxbore will do is TB and manifold openings. If you want your entire manifold ported, check out BlackTrax. As for power, I've seen plenty of dyno sheets that show a 5-8whp gain</TD></TR></TABLE>
so do u feel it was worth the 160 bucks?
Old Aug 19, 2006 | 10:14 AM
I'll answer that when I get back from the dyno (which won't be till the end of the month)
artevo9
Jun 11, 2009 09:16 PM
SPD DMN
Apr 17, 2008 12:19 AM
teri_vti
17
Nov 2, 2006 07:24 PM
Keyhole
Welding / Fabrication
11
Aug 31, 2005 08:00 PM
ludedimage
Aug 14, 2005 01:05 PM
