B16b rotational assembly
Old Aug 18, 2006 | 09:44 AM
B16b-EJ8's Avatar
Default B16b rotational assembly
If i wanted to take the rotational assembly from my B16b and put it into a B18c block it would work correct? I was looking at the Dart block with the 84mm bore...besides larger pistons what else would i need to make this work? I dont want to stroke it simply because i want to keep its rod stroke ratio
Old Aug 18, 2006 | 01:11 PM
d16vtecx's Avatar
Default Re: B16b rotational assembly (B16b-EJ8)
b16b rods won't fit(too short) cuz b18c deck is taller
Old Aug 18, 2006 | 05:15 PM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d16vtecx &raquo;</TD></TR><TR><TD CLASS="quote">b16b rods won't fit(too short) cuz b18c deck is taller</TD></TR></TABLE>
The B16A has a shorter block. The B16B (EK9 Civic Type R) shares the same block with the B18C series. Yes, it will work just fine.
Old Aug 18, 2006 | 05:30 PM
F20Cteg's Avatar
Default Re: B16b rotational assembly (Dogginator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">
The B16A has a shorter block. The B16B (EK9 Civic Type R) shares the same block with the B18C series. Yes, it will work just fine.</TD></TR></TABLE>
&gt;&gt;&gt;&lt;&lt;&lt;
Wytek9
Apr 23, 2008 09:32 AM
BryanM.
Nov 8, 2007 02:24 PM
BlueShadow
Nov 3, 2005 08:40 PM
gulftiresinc
12
Aug 14, 2004 10:39 PM
Honda Type R
Jan 14, 2004 01:40 PM
