wierd noise/friction
when i brake from time to time there is additional friction and when im moving slowly in reverse there is a howl type noise that i am hearing. what could be causing this? thanks in advance.
nobody here will laugh at you if you say what year, model of accord you have.
Brake dust in the rear drums can cause a howling sound, you might try to pull the drums and blast out the dust with a spray can of brake cleaner. adjust them up 12 clicks while you are in there.
