cooling fan stays on Please Help
Old Aug 18, 2006 | 07:41 AM
elnoyl's Avatar
Default cooling fan stays on Please Help
Cooling fan goes on when i turn the ignition and stays on whether the car is hot or cold. I unplugged both sensors on the upper radiator hose housing and the on the thermostat housing. The fan will shut off immediately when the ignition is off. I'm assuming the car thinks it's hot when it's really not causing the fan to go on any ideas? I swapped out the relay with a different one same result. I pulled the fuse it shut off.
Modified by elnoyl at 1:03 AM 8/19/2006
Old Aug 18, 2006 | 04:04 PM
elnoyl's Avatar
Default Re: cooling fan stays on Please Help (elnoyl)
anyone?
Old Aug 18, 2006 | 04:06 PM
thegeorge613's Avatar
Thermostat itself? Just an educated guess.
Old Aug 18, 2006 | 06:24 PM
elnoyl's Avatar
Default Re: (thegeorge613)
wouldn't my car overheat than?
fatl13ert
Oct 22, 2012 12:41 AM
EG2ENVY
16
Mar 2, 2009 12:41 AM
Donhonda84
Apr 4, 2007 08:36 PM
loup05
Oct 22, 2006 05:20 PM
darkfx
Aug 25, 2005 12:23 PM
