Tire rubbing
Old Aug 18, 2006 | 06:40 AM
ILcrxsi1's Avatar
I tell doctors what to do
Default Tire rubbing
I finally put on my sportlines with tokico blues yesterday. Now I am getting crazy rubbing from the pass rear tire, and only that tire. Do you guys think a crappy trailing arm bushing can cause this.
tires are 205 50 15's on rota grids, not sure of the offset
Old Aug 18, 2006 | 06:52 AM
ludesrv's Avatar
Trailing arm could cause a trailing arm to sag...but I highly doubt it.
Go get it alligned. See what they say. Could just be a camber issue. If it still rubs, you could raise it (if it's coilovers) or even go with a smaller tires.
Sorry, I'm not the best with suspension help, I'm jsut shooting out ideas.
Old Aug 18, 2006 | 11:39 AM
ILcrxsi1's Avatar
Default Re: (ludesrv)
Old Aug 18, 2006 | 01:47 PM
Dynodan's Avatar
Default Re: Tire rubbing (ILcrxsi1)
You should measure from the top of the wheel opening to the ground on the side that doesn't rub and then do the same on the side that does rub. If the dimension on the side that rubs is less, then that's your problem. It could be that the spring on the one side is different in length or rate allowing one side to be lower than the other. You would probably want to shim up the low side to even it out. You can also roll the fender lip upward to gain more tire to fender clearance.
Dan
Old Aug 18, 2006 | 02:10 PM
ILcrxsi1's Avatar
Default Re: Tire rubbing (Dynodan)
From the center of the arch down goes as follows 23 3/4 drivers side 23 1/2 passenger side. I would say it's pretty even given pavement variations and such.
here are pics, sorry I couldn't really get the same angle on both sides.
side that rubs
normal side
tried to give you an idea of camber, looks pretty even but camber can't really be measured with the naked eye
EDIT: ok i guess the camber does look a bit off
Old Aug 18, 2006 | 02:23 PM
1989CivicSi's Avatar
Yeah, looks to be a camber issue. On my car, however, my rear 1/4's were replaced due to rust sometime in the car's life and one side doesn't flare out as much as the other. Just throwing the possibility out there .
Old Aug 18, 2006 | 02:24 PM
ILcrxsi1's Avatar
Default Re: Tire rubbing (1989CivicSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1989CivicSi &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, looks to be a camber issue. On my car, however, my rear 1/4's were replaced due to rust sometime in the car's life and one side doesn't flare out as much as the other. Just throwing the possibility out there . </TD></TR></TABLE>x2 bondo maybe I'll try rolling them with the baseball bat method
Old Aug 18, 2006 | 02:31 PM
ILcrxsi1's Avatar
I guess I'll ad that this is crazy rubbing too, we're tlking like 15 mph left hand turns and this **** starts to rub. fast bumps okay, rolling bumps forget about it, hard bumps don't ask
Old Aug 18, 2006 | 05:20 PM
RapeV-8's Avatar
roll the fenders!!!just use a baesball bat and a hammer and some spray paint
Old Aug 18, 2006 | 05:29 PM
91civicEX's Avatar
Default Re: (igotcrx)
just take the wheel off and bang the lip flat with a hammer. didnt need any spray paint and it took about 5 min a side. my **** used to rub too, now no more.
Old Aug 18, 2006 | 08:17 PM
ILcrxsi1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by igotcrx &raquo;</TD></TR><TR><TD CLASS="quote">roll the fenders!!!just use a baesball bat and a hammer and some spray paint</TD></TR></TABLE>going to do this tomorrow, I think I'm going to skip the spraypaint and use undercoating
Old Aug 22, 2006 | 09:58 AM
RapeV-8's Avatar
how did it go?
Old Aug 22, 2006 | 10:20 AM
Suck my DX's Avatar
roll em..usually does the trick for minor tire rubbing...your cars not that low so im sure it will fix it...how does the ride feel? its possible the shock is defective and blew out already...
Old Aug 22, 2006 | 11:17 AM
ILcrxsi1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by igotcrx &raquo;</TD></TR><TR><TD CLASS="quote">how did it go?</TD></TR></TABLE>
It went well, I rolled it using my floor jack handle. The paint did crack but it's ok because I taped off the 1/4 panel and sprayed it with undercoating afterwards. I only had to bend the lip a little bit to get most of the rubbing to stop.
It still rubs when I hit hard bumps and stuff but it isn't nearly as bad as it was before. I went to an autocross on sunday and there was only one point in the course when the tire would rub. I think I'm going to roll it a little bit more to completely get rid of the problem.
Old Aug 22, 2006 | 11:20 AM
ILcrxsi1's Avatar
Default Re: (Suck my DX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suck my DX &raquo;</TD></TR><TR><TD CLASS="quote">roll em..usually does the trick for minor tire rubbing...your cars not that low so im sure it will fix it...how does the ride feel? its possible the shock is defective and blew out already...</TD></TR></TABLE>no the shocks are all still fine. the ride isn't bad at all it actually feels pretty close to stock when you aren't hitting any major dips in the road or anything. if the tokico's would dampen just a little more it would be perfect.
Old Aug 22, 2006 | 12:26 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ILcrxsi1 &raquo;</TD></TR><TR><TD CLASS="quote">side that rubs
The problem is that whoever did the body work on that quarter panel sucks ***. The wheel arch isn't even round - the radius shortens toward the rear of the car.
Old Aug 22, 2006 | 12:52 PM
ILcrxsi1's Avatar
Default Re: Tire rubbing (Targa250R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">
The problem is that whoever did the body work on that quarter panel sucks ***. The wheel arch isn't even round - the radius shortens toward the rear of the car.</TD></TR></TABLE>yep, but I bought the car this way and don't know who did the body work back there. all I knew is that the 1/4's had no rust
Old Aug 22, 2006 | 01:02 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ILcrxsi1 &raquo;</TD></TR><TR><TD CLASS="quote">yep, but I bought the car this way and don't know who did the body work back there. all I knew is that the 1/4's had no rust</TD></TR></TABLE>
You don't know what is under all that bondo.
Old Aug 22, 2006 | 01:05 PM
ILcrxsi1's Avatar
You don't know what is under all that bondo.</TD></TR></TABLE>probably a big fuggin mess
Old Aug 22, 2006 | 01:17 PM
RapeV-8's Avatar
how did you do at the autoX?!
Old Aug 22, 2006 | 01:20 PM
ILcrxsi1's Avatar
Default Re: Tire rubbing (igotcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by igotcrx &raquo;</TD></TR><TR><TD CLASS="quote">how did you do at the autoX?!</TD></TR></TABLE>I was sm2 and got rolled in to an open class. I came in last place
Old Aug 22, 2006 | 01:25 PM
88 rex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ILcrxsi1 &raquo;</TD></TR><TR><TD CLASS="quote">I was sm2 and got rolled in to an open class. I came in last place </TD></TR></TABLE>
open class?
Old Aug 22, 2006 | 02:53 PM
ILcrxsi1's Avatar
Default Re: Tire rubbing (88 rex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88 rex &raquo;</TD></TR><TR><TD CLASS="quote">
open class? </TD></TR></TABLE>yes I was the only one running street modified 2 so I got bumped into a different class with other cars that got bumped
Old Aug 22, 2006 | 03:12 PM
RCautoworks's Avatar
Default Re: (ILcrxsi1)
It went well, I rolled it using my floor jack handle. The paint did crack </TD></TR></TABLE>
Tape the fender next time before hand, it will help to prevent cracking.
Old Aug 22, 2006 | 06:34 PM
88 rex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ILcrxsi1 &raquo;</TD></TR><TR><TD CLASS="quote">yes I was the only one running street modified 2 so I got bumped into a different class with other cars that got bumped</TD></TR></TABLE>
Weird. I've been to autox's where I've been the only one in my class. Although, I wouldn't complain if they let me run in SM2 instead of DM.
mhax
Aug 25, 2014 07:22 PM
Brandeezy1
Jun 20, 2012 04:04 PM
EK FLY
11
Oct 11, 2006 08:19 PM
JoeCDN
May 18, 2004 01:23 AM
$N@kE
Jul 14, 2003 04:32 AM
