JDM P13 from a 93 model - Integrated Circuit and Fan Timer
Story So Far: In the kickpanel fuse box, theres a small IC box behind the fusepanel. It is different to the one i have just swapped out of my P12 AUDM equiped car. I also have no provision to plug in the Fan Timer Box which is located next to the ECU. Which leads me to my question:
Does the JDM P13 use an integrated Fan timer, in the ECU or is it part of the IC box in the fuse panel?
I have consulted the manual and this tells me different, being USDM biased it has a fan timer next to the ECU as per standard.
Also worth noting is I changed all my harnesses to the JDM ones as i added climate control and TCS. This harness has no plug for the fan timer, and the plug that goes to the IC box is different too.
Over to you!
Over to you!
ricanxplaya
Jun 7, 2011 07:42 AM
