Did y'all brace your turbos?
Old Aug 18, 2006 | 03:56 AM
motormike40's Avatar
Default Did y'all brace your turbos?
Did any of y'all brace your turbos, if so could you post a pic. My last setup wasnt braced, and I think that was the cause of the premature death of my manifold.
Old Aug 18, 2006 | 04:11 AM
DaveF's Avatar
Default Re: Did y'all brace your turbos? (motormike40)
we dont brace our 42R. and my street car isnt braced...i beat the **** out of it everyday too. so it goes through some heat cycles....
maybe you just bought a junk manifold ? and if not, you are stupid for not bracing the turbo with a nice thin wall mani.....
Old Aug 18, 2006 | 04:17 AM
Autoworks's Avatar
Default Re: Did y'all brace your turbos? (dturbocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">
maybe you just bought a junk manifold ? and if not, you are stupid for not bracing the turbo with a nice thin wall mani.....</TD></TR></TABLE>
My guess too.
I do not brace mine either, I haven't had a need to.
Old Aug 18, 2006 | 04:24 AM
delslo93's Avatar
Default Re: Did y'all brace your turbos? (Autoworks)
me either.
DaveF's Avatar
lets give him some hope......
POST a pic of your cracked manifold !!
Old Aug 18, 2006 | 05:56 AM
I really appreciate it, but I cannot find my camera, but the crack is 3/4 away around the turbo flange, and about 1/2 the way around on 2 of the exhaust flange welds. I showed it to a friend and he said that it looks like it was just welded with a wire welder, not tig welded, So could be a cheap-o manifold. Thanks all. Hopefully I can find my camera.
Old Aug 18, 2006 | 06:04 AM
quicksilver1689's Avatar
i ♥ snails
ssautoshit?
Old Aug 18, 2006 | 06:09 AM
yellowturbo's Avatar
with a good manifold you dont need to brace it... well it could always crack but maybe not from the weight of the turbo.
Old Aug 18, 2006 | 06:21 AM
Im not too sure of the make its not stamped anywhere, the guy threw in the kit when I bought his car. So now im on the hunt for a used one, thanks
Old Aug 18, 2006 | 06:30 AM
MidShipCivic's Avatar
If you road race you have to, these drag racers use freaking pipe for making manifolds that end up at least 50- 75lbs and tell you dont use one.
Old Aug 18, 2006 | 09:37 AM
Topdawgg's Avatar
what manifold?
Old Aug 18, 2006 | 09:44 AM
bigbadboy's Avatar
Default Re: (MidShipCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MidShipCivic &raquo;</TD></TR><TR><TD CLASS="quote">If you road race you have to, these drag racers use freaking pipe for making manifolds that end up at least 50- 75lbs and tell you dont use one.</TD></TR></TABLE>
what are we suppose to use then?? PVC pipe?? but anyway he prob had an ebay monifold
Old Aug 18, 2006 | 10:07 AM
VtecnTurbo's Avatar
Default Re: (bigbadboy)
no braces over here.
Old Aug 18, 2006 | 10:33 AM
GaRn's Avatar
Mine is braced.. It's cheap and easy to do.
Old Aug 18, 2006 | 11:26 AM
boostedcivicsir's Avatar
Mr. Badwrench
my t3t67ho isnt braced.
Old Aug 18, 2006 | 11:28 AM
.adam.'s Avatar
i just braced my downpipe before the flex section......i guess it helps take some of the strain off of the manifold
Old Aug 18, 2006 | 11:56 AM
PrecisionH23a's Avatar
A properly designed turbo manifold will not require the turbo or manifold to be braced. Due to thermal expansion you need to use the same materials IF you want to brace your manifold. If not one material will expand faster than the other and cause stress points which will lead to failure.
Old Aug 23, 2006 | 11:08 AM
Topdawgg's Avatar
mines not braced... but i have a strong manifold
Old Aug 23, 2006 | 11:58 AM
Crab-Cakes's Avatar
my old manifold was not braced...Im thinking its an ssautocrack...who made it?
antiJDM
Jan 28, 2008 08:09 AM
blue2000em1
Jul 9, 2007 07:57 PM
BlUAc
Welding / Fabrication
Dec 1, 2006 11:50 AM
ah789454
Sep 28, 2005 10:43 AM
MugenFlaredCRX
May 26, 2005 12:08 AM
