need help please.....fully built b18c5 making weird noise
i started up my car the other day and i heard this loud TOCK...TOCK....TOCK as i started up, but it went away soon after. now today i warm up my car and i notice this rattling sound coming from the engine when the revs are falling down. I reved it slightly from the engine bay and noticed the noise was coming from around cylinder #4. could this be a valve problem? needs adjusting?
my setup is as follows:
golden eagle sleeved b18c5
rollerwave pistons
eagle rods
ferrea super alloy valves, titanium springs and retainers
GSR Camshafts
Skunk 2 Adjustable Cam Gears
sc61 turbo
custom ramhorn manifold
custom downpipe and open exhaust
rollerwave pistons
eagle rods
GSR Camshafts
sc61 turbo
my ITR has wiseco forged pistons and they make all kinds of noise until it is warmed up-just part of owning forged....May also have loose valves but that is not normal for them to suddenly loosen.
Other than that, I would do a good visual inspection of the motor-your noise may be something small or it could be something big. You would be surprised what you can determine when you get a bright light and mirror and do a detailed inspection.
My VTX was making all kinds of noise a few days ago and it turned out to be a loose screw on the speedometer. I thought it was going to blow up and turned out to be nothing......
well the noise started just recently. i will check it out and pull the valve cover and do the valves just to make sure. the gsr cams work pretty good under boost. i made 500whp on pump gas so it seems ok.
space-tuna
Jan 23, 2004 04:46 PM
OneThirtyEight
Dec 22, 2001 05:49 PM
