What sounds like valve clatter at specific rpms?
Old Aug 17, 2006 | 08:58 PM
blumpfish's Avatar
Default What sounds like valve clatter at specific rpms?
I know I need a valve adjustment it sounds like a turbo diesel at idle.. but this problem has been getting worse and worse recently.. when the engine revs to 3.3-3.8k rpms it will sound like bb's are clinging around inside. it doesnt sound good at all it.
it will only happen during these rpms and no noticable difference in power. it will stop as fast as it started.. anyone know what this could be?
edit: i forgot to mention it will not do it when the engine is cold but once it starts to warm up even a little bit, it does it.
Old Aug 17, 2006 | 09:10 PM
IndySporty's Avatar
That's rod knock my friend. While it is mild like this you can just replace the rod bearings and call it good.
Old Aug 17, 2006 | 11:02 PM
blumpfish's Avatar
Default Re: (IndySporty)
are you sure? maybe i can get a video/sound clip up.. the best way to describe the noise is bb's + coffee can + paint mixer it sounds like its comming from the head, i listened to it with the hood open.. but who knows really where its ocmming from.. oh and my #3 cylinder spark plug is wearing down unusually faster than the others, if that has anything to do with it.
Old Aug 17, 2006 | 11:28 PM
jdm_dc_fan's Avatar
From: "That one guy with that one car" Kennewick WA
it could be your heat sheilds or exhaust. it happens to lots of 3rd gen. integras. same thing happened to me, then came time for a new motor and the noise was still their. motor was shipped from a good company so it wasnt the engine.
Old Aug 18, 2006 | 12:02 AM
blumpfish's Avatar
Default Re: (jdm_dc_fan)
i dont think it is the heat sheild it is clearly comming from inside the engine, and like i said it happens exactly at these rpms no variations it happens like clockwork everytime
Old Aug 18, 2006 | 12:26 AM
Spoon Sports's Avatar
Suit up
Default Re: (blumpfish)
I have the same problem. I did a swap recently and the motor and tranny were clean but I still get that weird noise.
Old Aug 18, 2006 | 12:32 AM
redsolturbo's Avatar
Default Re: (Spoon Sports)
if its a b16a1 its probably worn lma springs, its not until the a2 heads that they started using uprated lma springs
Old Aug 18, 2006 | 07:42 AM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: (redsolturbo)
LMA=Lost motion assemblies..
See: https://honda-tech.com/zerothread?id=726701
and search under the archived material..
Mine drove me nuts until I replaced them..
Old Aug 18, 2006 | 08:19 AM
SIred91's Avatar
Rainman
Default Re: What sounds like valve clatter at specific rpms? (blumpfish)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blumpfish &raquo;</TD></TR><TR><TD CLASS="quote">I know I need a valve adjustment it sounds like a turbo diesel at idle.. but this problem has been getting worse and worse recently.. when the engine revs to 3.3-3.8k rpms it will sound like bb's are clinging around inside. it doesnt sound good at all it.
edit: i forgot to mention it will not do it when the engine is cold but once it starts to warm up even a little bit, it does it.</TD></TR></TABLE>
That sounds like detonation to me. Mine did it to, right in the same revs yours is, and after cleaning the engine internaly it went away immediately.
Run a can of BG44K through it. Best fuel/carbon cleaner on the market.
Old Aug 18, 2006 | 09:37 AM
blumpfish's Avatar
Default Re: What sounds like valve clatter at specific rpms? (SIred91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIred91 &raquo;</TD></TR><TR><TD CLASS="quote">
Run a can of BG44K through it. Best fuel/carbon cleaner on the market.</TD></TR></TABLE>
I have used seafoam in the past, maybe 7k miles ago, ill have to try that out.
Old Aug 18, 2006 | 12:29 PM
91SiZ6's Avatar
The heat shield on the cat tends to make the same noise at the same rpm range.
Old Aug 18, 2006 | 12:39 PM
baconcrx's Avatar
Default Re: (91SiZ6)
heat sheild on the cat eh? i have a pinging noise that sounds to me like its coming from near my timing belt... but it might be the heat shield or something... it also started after i drove 400miles straight with only a 15min break...
EG-SIXV-TEC
13
Jun 15, 2009 12:49 PM
wade
Mar 18, 2009 01:30 AM
movingIIshadow
May 7, 2006 04:01 PM
Ideal
Sep 14, 2005 02:43 PM
Matt B
Feb 18, 2004 09:41 AM
