h22 in ef fuel problem
The below thread is for the resistor wire up how to...by the way the mount kit looks familar
https://honda-tech.com/zerothread?id=1278396
I did this diagram a while back... for the dizzy wiring...
could i have bad fuel injectors or do i need a mpfi harness because i think the one we have is a dpfi harness and i also have 3 wires left from the dizzy.
you need to have multi port in the end...since the h22 is multi port...hf/si crx models and civic models 88-91 are multi port DX/STD is dual port...you may want to search for dual port to multi port wiring on here...I have never done the swap from dual to multi always easier to start out with a multi harness...
i ran the brown, red, blue, and yellow wires to the computer and the others to the resistor box and the yel/blk to th dizzy 12v and still doesnt wrk.
First you must convert to multipoint fuel injection
http://www.geocities.com/c_rexboy/mpfi.html
Then convert to obd1.
There are a few companies that make harnesses or you can do it yourself.
You only have to use a resistor box if you use peak and hold injectors(obd0).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4thgenhtch »</TD></TR><TR><TD CLASS="quote">Looks like a sic sleeper </TD></TR></TABLE>
Looks more like there's tons of weight reduction done to the car.. Sleeper?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jesterian »</TD></TR><TR><TD CLASS="quote">
Looks more like there's tons of weight reduction done to the car.. Sleeper?</TD></TR></TABLE>
I see A stock *** hatch am i missing something?
I see A stock *** hatch am i missing something?</TD></TR></TABLE>
look at the swiss cheesed rear bumper and the left rear window, not glass in there.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4thgenhtch »</TD></TR><TR><TD CLASS="quote">Expanding Image Ownes me
</TD></TR></TABLE>haha fo real
</TD></TR></TABLE>haha fo realThread
