When using OEM rings do you need to file?
Old Aug 17, 2006 | 05:07 PM
white90rexsi's Avatar
Default When using OEM rings do you need to file?
I am building a gsr motor and used all oem parts. I installed the pistons, spun it over and everything was fine. Now I have a scratch down one cylinder wall. Im going to take the pistons out and check the gaps. Do you normally have to file honda rings?
Old Aug 17, 2006 | 05:17 PM
unknown0001's Avatar
Default Re: When using OEM rings do you need to file? (white90rexsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by white90rexsi &raquo;</TD></TR><TR><TD CLASS="quote">I am building a gsr motor and used all oem parts. I installed the pistons, spun it over and everything was fine. Now I have a scratch down one cylinder wall. Im going to take the pistons out and check the gaps. Do you normally have to file honda rings?
You should have checked the gap before installing the rings onto the pistons. Best would have been to put the ring itself into the cylinder and check for gaps then.
You have to file them accordingly if the clearance required isn't achieved.
Old Aug 17, 2006 | 06:43 PM
civickid03's Avatar
you file them and you file them now.
Old Aug 18, 2006 | 03:26 AM
Default Re: When using OEM rings do you need to file? (civickid03)
Haha, Maybe we will do this on sunday dave!
Old Aug 18, 2006 | 12:46 PM
91SiZ6's Avatar
Dude, you didn't check your ring end gaps before putting the block together? Big mistake. You ALWAYS do that. It's as important as checking bearing clearance.
Old Aug 18, 2006 | 07:25 PM
Default Re: (91SiZ6)
I feel so stupid! I did this motor at school and my teacher said nothing about gaping them. I figured since he said nothing, and since they where oem rings I did not have to worry. I called the machine shop today and he said I just need to gap the top compression ring. Is that correct?
Old Aug 18, 2006 | 07:44 PM
Default Re: (white90rexsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by white90rexsi &raquo;</TD></TR><TR><TD CLASS="quote">I feel so stupid! I did this motor at school and my teacher said nothing about gaping them. I figured since he said nothing, and since they where oem rings I did not have to worry. I called the machine shop today and he said I just need to gap the top compression ring. Is that correct?</TD></TR></TABLE>
http://www.circletrack.com/howto/1818/
http://www.dol.net/~dave.reed/tips.htm
Old Aug 19, 2006 | 07:04 AM
Default Re: (Mr.RHTuner)
Great link! I was looking thru my factory repair manual and it does not say anything about fileing. It says how to check the ring gap and it sayd " If to much clearence, check cyl bores, if not enought clearence, make sure you have correct rings. Im going to check the clearence, but chances are it should be right. If it is to tight, can you file these oem rings?
Old Aug 19, 2006 | 08:35 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by white90rexsi &raquo;</TD></TR><TR><TD CLASS="quote">Great link! I was looking thru my factory repair manual and it does not say anything about fileing. It says how to check the ring gap and it sayd " If to much clearence, check cyl bores, if not enought clearence, make sure you have correct rings. Im going to check the clearence, but chances are it should be right. If it is to tight, can you file these oem rings? </TD></TR></TABLE>
Yes if the clearance is tight, you can file the rings a bit to make it appropriate. I've seen and heard of it being done before
Clerique
Oct 4, 2008 05:14 PM
PhatBoy5015
Aug 7, 2006 08:52 AM
psegs80
Oct 22, 2005 03:50 PM
quik1
Jun 9, 2004 07:48 PM
99B16Si
Dec 25, 2002 08:39 PM
