final drive
Old Aug 17, 2006 | 02:36 PM
DARKTEG_'s Avatar
Default final drive
what the heck is final drive?
Old Aug 17, 2006 | 03:25 PM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
Default Re: final drive (gonk_1)
the output shaft/pinion and the differential ring gear.
Old Aug 17, 2006 | 03:26 PM
DARKTEG_'s Avatar
Default Re: final drive (not so civic)
which means what?
Old Aug 17, 2006 | 03:35 PM
it's the second/last set of gear reduction...the final drive.
Old Aug 17, 2006 | 03:37 PM
DARKTEG_'s Avatar
can you put that into english and really explain it please
Old Aug 17, 2006 | 03:45 PM
if a car has a 5.0 final drive, then the pinion turns 5 times per one ring gear revolution.
Old Aug 17, 2006 | 03:46 PM
DARKTEG_'s Avatar
ok..i'm starting to slowly understand...
Old Aug 18, 2006 | 09:55 PM
pos_cd5's Avatar
to skip all the mechanical mumble jumbo...the higher the # your final drive is the better acceleration you'll have but lose out on top speed and vise versa...
Old Aug 19, 2006 | 06:56 AM
DARKTEG_'s Avatar
Default Re: final drive (pos_cd5)
anyone that doesn't understand it just reAD this... cause i completely understand know
http://www.team-integra.net/se...D=707
671XxDaRkCyDexX
Aug 26, 2008 06:46 AM
Midori Green
Apr 30, 2008 09:11 PM
thorshammer56
Honda Motorcycles
Jun 6, 2007 08:05 AM
bocian
Apr 16, 2002 08:58 PM
