SWAPING IN A D16Z6 MOTOR WHAT DO I NEED ?
Old Aug 17, 2006 | 02:07 PM
Manny86's Avatar
Default SWAPING IN A D16Z6 MOTOR WHAT DO I NEED ?
I HAVE A 91 CRX IM GOING TO PUT IN A D16Z6 MOTOR I KNOW I NEED OBD1 DIST OBD1 ECU JUMPER HARNESS FOR BOTH AND ECU 4 WIRE O2 SENSOR WHAT DO I DO ABOUT THE WIREING HARNESS CAN I USE MY FACTORY ONE IF SO WHAT OTHER WIRES DO I HAVE TO RUN FOR THE MOTOR TO RUN RITE ?
Old Aug 17, 2006 | 02:25 PM
Magick211's Avatar
Default Re: SWAPING IN A D16Z6 MOTOR WHAT DO I NEED ? (Manny86)
Yes you will need to use your factory wiring harness, If you have a DX then you will need to do a dpfi to mpfi wiring conversion on your harness. You can do it yourself (just search mpfi here on honda-tech) or you can send you harness to http://www.rywire.com and have it done.
Old Aug 17, 2006 | 02:39 PM
jhota's Avatar
YOU KNOW THAT ALL CAPS IS CONSIDERED SCREAMING, RIGHT?
Old Aug 17, 2006 | 05:42 PM
HondaPartsHero's Avatar
Technical Hero
if you have an Si or HF you can use your wiring harness and add the wiring for VTEC solenoid and VTEC pressure switch. You will also have to run the 4 wires for the O2. You will also either have to extend the wires for your fan switch from the back of the block to the water outlet on the z6 motor's fan switch.
Old Aug 17, 2006 | 07:55 PM
suspendedHatch's Avatar
Default Re: SWAPING IN A D16Z6 MOTOR WHAT DO I NEED ? (HondaPartsHero)
You don't need an OBD1 distributer. You need a D16Z6 distributer. No other distributer will work properly.
h22-hatch
Mar 8, 2010 10:09 AM
grrrrrr4me
Mar 29, 2005 08:26 PM
madswapper
Mar 28, 2005 07:51 PM
Amf_crx
Mar 20, 2004 02:52 PM
SOHCEK-Turbo
Aug 12, 2003 01:41 PM
