do i need a tune up?
Old Aug 17, 2006 | 01:43 PM
Fat Chick Magnet's Avatar
Default do i need a tune up?
Modified by dc2rtek at 10:23 AM 9/30/2006
Old Aug 17, 2006 | 01:48 PM
VtecAdvantage's Avatar
Default Re: do i need a tune up? (dc2rtek)
theres quite a few things involved in tune-up/maintainance - how many miles do you have on your 'teg?
Old Aug 17, 2006 | 10:08 PM
itS a 95 gsr w/ 85k miles
Old Aug 19, 2006 | 11:11 PM
Jimmii's Avatar
Default Re: (dc2rtek)
check your spark plugs. if they are black i highly suggest you change those. check your timing also. that could be par of your problem
Old Aug 20, 2006 | 04:09 AM
blackdelslo's Avatar
Default Re: (LFA Squad: Yimmy)
Sounds like that car is in need of a lot of maintenance work.
Old Aug 20, 2006 | 07:21 AM
be18see1's Avatar
mine too bro. im at 90000 and just replaced 2 motor mounts, the spark plugs/wires, i need p/s fluid, and my suspension bushings are all rotted and torn. woot for the neglected dc's.
Old Aug 20, 2006 | 10:34 AM
JDMxNguyeN's Avatar
Default Re: do i need a tune up? (be18see1)
how much was it to replace ur motor mounts??? i need to replace all of my motor mounts :-( too much downshifting.... ahha
Old Aug 20, 2006 | 11:07 AM
PrinceAli132's Avatar
Default Re: do i need a tune up? (JDMxNguyeN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMxNguyeN &raquo;</TD></TR><TR><TD CLASS="quote">how much was it to replace ur motor mounts??? i need to replace all of my motor mounts :-( too much downshifting.... ahha</TD></TR></TABLE>
It will depend on which route you choose; inserts, new mounts (hasport, innovative), OEM.
Ali
Old Aug 20, 2006 | 11:13 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2rtek &raquo;</TD></TR><TR><TD CLASS="quote">I have 2 broken motor mounts.</TD></TR></TABLE>
Are the actuall mounts broken or are the inserts just torn up?
Ali
Old Aug 20, 2006 | 06:36 PM
be18see1's Avatar
i bought oem ones for about $35 apiece. the top right/left and rear are like 60 apiece.
Old Aug 20, 2006 | 06:55 PM
Motor mounts were the 1st thing I had to replace on my car - they were torn up pretty bad. Alls i did was get inserts all the way around.. probably cost me around 60 for all of them.
Timing belts usually don't need to be replace until about 90k but if you do plan on changing it out - change ALL your belts.
a few things i can name off the top of my head:
-oil and filter change
-air filter
-dizzy cap and rotor
-PCV valve
-spark plugs & wires
-VTEC selenoid gasket (if you have vtec)
Thats all i can think of right now - of course theres other things like pads and rotors, brake fluid swap, and radiator flush.
good luck
Old Aug 20, 2006 | 09:35 PM
SKANK ASS johNNY's Avatar
Default Re: do i need a tune up? (VtecAdvantage)
going to need this for later! ttt
jeremyrocksursox
Mar 6, 2010 03:03 PM
EduardoDC5
16
Jan 8, 2009 10:52 AM
EGcivicBoy
12
Dec 25, 2003 12:40 PM
