Will 18's fit in '98 Acd sdn?
Old Apr 25, 2002 | 04:04 PM
g's integ's Avatar
Default Will 18's fit in '98 Acd sdn?
My buddy is planning to put 18's on his ride. We're afraid they won't fit. Should he get coilovers or springs?
Old Apr 25, 2002 | 04:27 PM
MY99GSR's Avatar
Default Re: Will 18's fit in '98 Acd sdn? (g'sinteg)
Essentially, you are closing the gap between the wheel and the fender. Right? With 18" rollers, you are not really allowing (your friend) to lower his car as much as he probably thinks he can. There may be some clearance issues to resolve, especially with the suspension, and wheel offset.
Old Apr 25, 2002 | 04:29 PM
98AccordEX's Avatar
yes they'll fit. get 225/40/18 tires. i have those tires and i am dropped about 2.5". you cannot put people in your backseat. i had like a 100 lb girl in my backseat and it made me rub goin around turns. and if you have a kit i hope its urethane. you wont have wheel gap at all. just get them. make sure the offset is right. i dont know what it should be. dont know what mine it but they fit good. Konig Verdicts if you wanna see if you find what the offset is
Old Apr 25, 2002 | 06:44 PM
aznchino16's Avatar
Default Re: Will 18's fit in '98 Acd sdn? (98AccordEX)
wassup, i got Racing Harts C5's 18 inch. It fit wit 225/40 tires. The only thing that's different is my car is not dropped yets. I don't know if i get the Eibach pro kit (1.5 drop) will effect my camber or alignment.
Old Apr 25, 2002 | 08:37 PM
dannyboi's Avatar
I got 18x7.5 w/ 215 40 on my '98 sedan w/ circuit pro coil overs lowered all the way in front. I have no rubbing at all , even w/ my car packed!
Old Apr 25, 2002 | 08:39 PM
Krow's Avatar
Default Re: Will 18's fit in '98 Acd sdn? (aznchino16)
I put a set of 18's on my integra just to see how it would look, and I was like Don't do it.
Old Apr 25, 2002 | 10:45 PM
scrubachu's Avatar
Default Re: Will 18's fit in '98 Acd sdn? (Krow)
this aint the appearance forum yos. wrongplace to post. destroy it SOHC.
Old Apr 26, 2002 | 06:58 AM
FAZ98Accord's Avatar
I have a 98 sedan and just put Axis se7en's 18 x 7.5 with 42 offset. They fit with a very slight protrusion on the front wheels. I will need to make some camber adjustments when I lower the car to get the front wheels to tuck. If you buy 18's with a larger offset (44 or 45) you shouldn't have a problem.
Old Apr 26, 2002 | 07:00 AM
SOHCArchangel's Avatar
Default Re: Will 18's fit in '98 Acd sdn? (scrubachu)
=D
chrisnick
Aug 11, 2013 03:40 PM
integlspwr2k
Jun 8, 2005 02:03 PM
Geeq
Jun 7, 2004 07:48 AM
94teggy
Feb 5, 2004 09:47 AM
hondacivic4g
Apr 15, 2002 06:52 PM
